20 Most Recent
Kenwood eXcelon KDC-X689 Questions & Answers
I have a kenwood kdc-x689.
There are more fuses which are to be checked other than the one at the back , The power supply fuse should be within the fuse box of the car , Do check them and you'll be fixed for sure , Just find the fuse box and how to replace one using your owners manual
thank you
Need to find out the four digit code
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Cd player locked
It has a defective ribbon cable between the face and the motherboard. This is a common repair, but must be done by a repair shop. My shop charges around $60-70 for parts and labor for that repair, to give you a ballpark of what to expect.
Need the code
Hi, If this Kenwood has a mode button, ie a button that will decide which source to play like radio,cd,tape or aux try pressing the main power on button and the mode button at the same time for 5 seconds it may then display the word code and allow you to put the code in if you know it, if you dont, you will need to have its memory erased by a kenwood dealer.
