20 Most Recent
Kenwood KDC-2011S CD Player Questions & Answers
Kenwood KDC-2011S display blinks
Download the MANUAL here.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=037b5697f7192f25431654464fa26ba6&q=Kenwood+KDC-2011S
Enjoy!
;) Mak
11/24/2018 2:25:56 AM •
Kenwood...
Answered
on Nov 24, 2018
I have power to the receiver but i have no display
Since there is power to the receiver, you will have to open the set and trace from the main pcb. see if the smps circuit ( main Power) gives the required voltages to the processor boards. You will have to use a multimeter for checking the +5 to the micro processor, the display voltages, the cord to the display, the display drive. only a though test on these units will you be able to arrive at the issue. If there is no response, you will need to replace the main board. hope this helps for a decision. Good day
7/9/2010 9:16:20 AM •
Kenwood...
Answered
on Jul 09, 2010
Playing copied cds
go out and get a cd player lense cleaner cd and let it run for the time it gives. It is more than likely a dirty laser lense. Good luck.
1/6/2009 9:12:21 PM •
Kenwood...
Answered
on Jan 06, 2009
Clock
Enjoy!
12/21/2008 7:20:04 PM •
Kenwood...
Answered
on Dec 21, 2008
I wanna hook an ..
Yes. Just run your RCA leads to the amp (after properly wiring it). You can use either the front of rear pre-out connections. If your amp has a built in crossover, Use the low-pass filter setting at around 60Hz.
A copy of the owner's manual can be found here if you need it:
http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/#_
Hope this helps!
9/1/2008 6:14:29 PM •
Kenwood...
Answered
on Sep 01, 2008
Cd player
The yellow wire goes to + (hot) 12 volt constant, red wire goes to ignition switch, Hook up your amp together with the red wire
(switched) and the amp will come on with the ignition switch.
Blue and white wire is for the power antenna.
Leadispenser
8/27/2008 2:28:18 AM •
Kenwood...
Answered
on Aug 27, 2008
Kenwood kdc 3011 cd player
Have you tried the balance and fader control?
Also make sure the ground or - negative wire has a good connection for that speaker from the back of the unit. Or it could be the internal amplifier it self.
Dan
8/27/2008 2:00:47 AM •
Kenwood...
Answered
on Aug 27, 2008
Setting the clock
Enjoy!
;) Mak
8/6/2008 5:18:17 PM •
Kenwood...
Answered
on Aug 06, 2008
