20 Most Recent Kenwood Excelon KAC-X521 Car Audio Amplifier Questions & Answers
its a decently old amp i would replace amp. the capacitors are probly going bad kenwood is notoryesly bad for that
Kenwood Excelon... | Answered on Jul 08, 2010
If disconnecting all power wires, and replacing all fuses (including inline ones) doesnt reset it. then its toast. Hate to break it to you :( Contact the manufacturer if you feel it is under warranty.
Kenwood Excelon... | Answered on Apr 14, 2010
2 things could shut your amp...to low of a ohm load, or very low voltage drops. I need some more info to help you out.
1. Is the amp really hot when it shuts off?
2. Is it a mono sub amp or 2 channel stereo amp?
3.What ohm's are your subs & are they SVC or DVC?
4. How do you have them wired to the amp?
You can email me at thefowlerfam09@yahoo.com I have a idea whats going on just need some more info.
Kenwood Excelon... | Answered on Apr 03, 2010
Red lights and error codes usually mean a fault ha occurred. Usually blown output transistors or input power supply caps are to blame. Don't try to fix unless you are comfortable with doing that and have the equipment. Also try emailing Kenwood tech support, they will be happy to tell you exactly what the error code is and possibly why it is happening.
Kenwood Excelon... | Answered on Dec 15, 2009
Hello mogly20,
The amp probably won't know if it's you or the homeless guy, so try smashing a glass bottle on it like he did. If that doesn't work, I'd recommend you locate another homeless guy and buy another amp.
Hope this helps.
Kenwood Excelon... | Answered on Aug 09, 2009
bad speaker connection or rca check them
Kenwood Excelon... | Answered on Aug 07, 2009
check speaker and power source
low voltage check power source
Kenwood Excelon... | Answered on Jun 26, 2009
check your remote connection
check ground, most amps required that you ground straight from the batt. also check your rca jacks
Kenwood Excelon... | Answered on Mar 06, 2009
wireing an amp can be tough it starts from the e.q.the e.q. must have a sub out.
Kenwood Excelon... | Answered on Mar 02, 2009
I do believe this is caused by one of your amp fuses. Depending on which + on the amp is being used. That channel has a blown fuse. have you tried running + and -, + and - to both channels to see if both subs worked? If one sub doesn't then it's a blown fuse or scarred fuse and needs to be changed.
Kenwood Excelon... | Answered on Feb 11, 2009
According to page 7 of the radio's manual, E-02 means the amp has failed and DC is being applied to the speakers. It also says "Turn the POWER switch "OFF" and release the protection."
Kenwood Excelon... | Answered on Mar 05, 2008
you probably blew it up. Whenever you smell that smell it is almost always a capacitor in there that blew.
Kenwood Excelon... | Answered on Jun 19, 2007
Page 13 says it is activated by the user. It tells you to treasure the code. Ask the last user. Take it to a Kenwood Service centre. Try a reset as shown on Page 3 of the manual.
http://manual.kenwood.com/files/B64-4039-00_K.pdf
Kenwood Car... | Answered on Dec 03, 2019
VIDEO CARD READER OF UNIT IS BAD YOU HAVE TO FIND A TECH SUPPORT WITH KENWOOD TO FIX
Kenwood Car... | Answered on Nov 29, 2019
Any video file that is .avi requires codecs. Most players don't have a comprehensive list of codecs on their chips though they have divx and xvid on many devices these days. divx and xvid are codec types of .avi. Types such as .mpg or .mpeg or mp3 or mp4 are older and more compatible with most equipment. mkv may not work
Kenwood Car... | Answered on Nov 12, 2019
Kenwood Excelon KAC-X521 Car Audio Amplifier Logo
19 questions posted
Top Kenwood Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Car Audio & Video
Most Popular Question
kenwood excelon kac x811d blinking e 03
  • Car Audio & Video
