20 Most Recent Kenwood KAC-9152D Car Audio Amplifier Questions & Answers
2answers
What is the p. con on the back of the kenwood
Power control wire - tells the amp to turn on, usually connected to the blue/white or blue wire when blue/white is not present on aftermarket radios. On factory systems you usually want to hook up this connector to an acc source on the car
10/8/2017 4:08:55 PM • Kenwood... • Answered on Oct 08, 2017
0answers
My Kenwood kac9152D turns on but why dose the red light on the top keep flashing?
The manual only says the power indicator burns when the power is on. 25372094-ptmniwyvtjobac0k42nxowvq-3-0.png I can't find anything about it also should flash. The only thing I can think of, it has detected an error, like a blown amp or a low impedance on a speaker terminal. Here is the manual: http://images.kenwood.eu/files/prod/29/5/KAC-9152D_9102D_8152D_8102D_(EN).pdf
1/17/2015 5:03:41 PM • Kenwood... • Answered on Jan 17, 2015
Amp has power, turns on with stereo, but sub isnt
if you have a protection light that is on it means the amp is in protection mode and wont allow any power to the sub this usually happens when the sub or wiring shorts out or if there is an internal failure in the amp or if its overheating. check the wires and connections and test your sub on another amp.
5/13/2014 12:36:45 AM • Kenwood... • Answered on May 13, 2014
I have a KAC 9152d with a red light on.
your ampifier is in protect mode, try to dettache the speaker and turn on it.if the green ligh on ,one of your speaker is deffective but still the red light on theres something wrong with your amp.
4/13/2014 11:57:50 PM • Kenwood... • Answered on Apr 13, 2014
0answers
WIRE DIAGRAM FOR HOME SECURITY CAMERA
the diagram is supplied with the camera. if not, find the connectors that the camera uses to send the tv signal.find the model number of camera and setup the power connections and route the signal cable to your tv or server or recorder.setup the power cable and connect it to your power source. provide more information about your setup.
11/15/2013 4:34:15 AM • Kenwood... • Answered on Nov 15, 2013
0answers
How to???
Be the first to answer 3/5/2013 8:13:50 PM • Kenwood... • Posted on Mar 05, 2013Be the first to answer
Kenwood repair manual
I have the Kenwood KAC-9152D Repair Owners Manual. This is my E-Mail address. [email protected] send my a e-mail. & I will e-mail back 2 U w/the Manual ATTACHED
12/21/2011 12:47:08 PM • Kenwood... • Answered on Dec 21, 2011
I have a 1800 watt
Check your amp's fuse(s), it may be blown.
9/26/2011 4:21:18 AM • Kenwood... • Answered on Sep 26, 2011
I have a kenwood kac-9152d
make sure it's well ventilated. If there's no air flow, then there is no way of cooling down and to protect itself it will shut off. Make sure the speakers are wired correctly as per amp specs. too many subs or subs connected improperly can draw too much current and shut the amp off, but you will notice this when you turn up the volume to a certain point and the amp shuts down.
9/26/2011 4:17:44 AM • Kenwood... • Answered on Sep 26, 2011
Kenwood KAC-9152D Car Audio Amplifier Logo
Popular Tags
146 questions posted
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Car Audio & Video
Most Popular Question
amoung many other people
  • Car Audio & Video
