20 Most Recent
Jensen JER-321 Remote Control Questions & Answers
Remote not working
Check the remote control for its infrared emission. Check it with fresh batteries. Before inserting batteries, check whether there is dust or rust accumulated at the battery contacts inside the battery compartment. If you wish to get more details about how to check and repair a remote control, check the site linked here.
Pull up previous posts, either by type in the Brand name to
your set in its search box, or view it in
Mosaic / Timeslide / Flipcard option.
Select view option by the drop-down view box, at the top left or
the display window.
Codes for lexus dvd
Check these codes. 0628,0719,0664. If you wish to get more details, check this
link.
http://electrohelponline.blogspot.com/ Setup code list and setup proceedings to
many popular brand remote controls are given. Pull up older posts there. More
than Nine and half Lakh viewers cannot be wrong.
Need a code list for a jensen 321 remote control
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not
in the address bar of your browser], and click search. It is an electronic equipments service help
site. All details you want are
there. Note the position of
hyphen in between words in site name, when you type it in. The site will appear as it is in
web; subtitled as service help to electronic home entertainement equipments.
Pull up older posts.
You can gather all details.
Sometimes, clicking on the ads by the side and bottom of each post might
give you more details.
Three digit codes for Panasonic are: 003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
four digit codes and setting procedure are described in detail in above site.
I have a jensen 321
1.Manually turn on the component you want the remote to control.
2.Press and hold the component key (TV, VCR, Etc..) you wish to program. The illuminated ON-OFF key turns and remains on.
3.While holding the component key down, press and hold the ON-OFF key. The illuminated ON-OFF key turns off.
4.After holding down both keys for three seconds, the illuminated ON-OFF key turns back on.
5.Release both keys. The illuminated ON-OFF key remains on.
6.Press and release the ON-OFF key repeatedly until your component turns off. Wait four seconds between each keypress. Each time you press the ON-OFF key, the illuminated ON-OFF key blinks and the next code in the list is sent. This process continues until all of the codes in the Code lists have been searched. If your component turns off, you have found the correct code.
7.Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON-OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored.
Or if you need to type in a code. MITSUBISHI Codes: 004/ 005/ 009/ 022/ 046/ 081/ 089/ 132/ 133/ 180
How do i set my tv
Configuring codes:
- Turn on the component that you want to set up.
- Hold the component key down until the green indicator
light comes on. The green light should come on after approximately 3
seconds.
- Release the component key.
- If you are programming the DVD or CD device press the
"action" key. The red indicator light will come on.
- Within thirty seconds, enter in a 4-digit code number.
The component key lights will blink with an upward motion when a code has
been successfully entered. In this case proceed to step #5. If the code
has not been successfully entered, the componment lights will not blink.
In this case return to strep #1 and start over.
- Test code by pressing "Power" key. If the
component turns off, you've got the right code. Follow the same
instructions to set up your other components. If the component doesn't
turn off, return to step 2 and use the next 4-digit code listed.
Note: If none of the codes
turn your component off, try the Auto Code Scan function.
Auto Code Scan:
The Auto Code Scan feature allows you to set up
your components without having to enter in code numbers. The Jensen will do the
work for you! (It may take a few minutes to find your code using this method.)
- Hold the component key down until the light comes on.
The green light should come on after approximately 3 seconds.
- Press "0" - "9" The green light
will blink as codes are sent.
- As soon as the remote turns your component off, press
the "action" key. (You have 1 second in which to press the
"action" key to save the code.) The component key lights will
blink with an upward motion when a code has been successfully entered. The
component is now programmed. To find that code, proceed to Code Readback.
- If none of the codes turn your component off, return to
step 2 and start over. Thank You
How do u enter codes on remote
To program this remote you should do the next steps:
3.While holding the component key down, input the 4 digit code for your component (TV, VCR, etc), after you press the first digit the light on the ON-OFF will go off, continue with the remaining digits.
4. After the 4 digit code has been entered, press the power button, if it works you get the right code, if not, repeat steps with another code in the list.
Lost my instructions to operate the remote
Configuring codes:
1.Hold the component key down until the green indicator light comes on. The green light should come on after approximately 3 seconds.
2.Release the component key.
3.If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
4.Within thirty seconds, enter in a 4-digit code number. The component key lights will blink with an upward motion when a code has been successfully entered. In this case proceed to step #5. If the code has not been successfully entered, the componment lights will not blink. In this case return to strep #1 and start over.
5.Test code by pressing "Power" key. If the component turns off, you've got the right code. Follow the same instructions to set up your other components. If the component doesn't turn off, return to step 2 and use the next 4-digit code listed.
Note: If none of the codes turn your component off, try the Auto Code Scan function.
Auto Code Scan:
The Auto Code Scan feature allows you to set up your components without having to enter in code numbers. The Jensen will do the work for you! (It may take a few minutes to find your code using this method.)
1.Turn on the component that you want to set up.
2.Hold the component key down until the light comes on. The green light should come on after approximately 3 seconds.
3.Release the component key.
4.If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
5.Press "0" - "9" The green light will blink as codes are sent.
6.As soon as the remote turns your component off, press the "action" key. The component key lights will blink with an upward motion when a code has been successfully entered. The component is now programmed. To find that code, proceed to Code Readback.
If none of the codes turn your component off, return to step 2 and start over.
Thanx
I need to use video 1,2 or color stream but I
Is there possibly a button on the front of your tv to the left of the volume buttons lable ant/video? If there is use that button to cycle through all AV connections. Hope that helped
REMOTE CONTROL
Here you go...it took a while but I found the user manual cause I ROCK....that'sright say it with me....He...Rocks...hehe...but anyway here is the linkaddress if the link doesn't work...
http://safemanuals.com/user-guide-instructions-owner-manual/JENSEN/JER-321-_E
I hope this helps...good luck and thanks for rating my effort....the Fang
Download the complete user guide (3257 Ko)
