20 Most Recent
Jensen VM9410 Car DVD Player Questions & Answers
Wire diagram i think
pink wire if its to go to ground then any metal is ground or negative not live in other words they say the handbrake so you cant use it whilst driving so any metal should do for this ok.
Are you wiring it to amp or not?
Also the mute only wires into say phone cradle or something that would mute the stereo say if you had phone in craddle this would mute the sound so you could here the call. so not needed unless you have phone craddle.
If the two lives are wired in and the ground black when you earth the pink then it should switch on let me know if this happens.
Auto ant is for the arial on car if this goes up and down on motor if not then its not needed
Ill check on dimmer/illumination ok but bare with me for couple of hours just popping out but will get back to you then ok
Whenever I turn on my
code is either 543210 or 012345 make sure the yellow wire is on a constant power source and the red is connected to ignition on and of course black is ground
WHERE CAN I GET MY
try going to audiovox.com and see if they can help you. Audiovox owns Jensen.
Is there a way to make player play without hooking
The e-brake wire is there for liability reasons. If you're in an
accident and there is a video playing, you will probably be liable.
Also, it is illegal almost everywhere to have a video playing that can
be viewed by the driver. This could get you pulled over and fined. This is why the brake wire is there, so the player knows the vehicle is not moving.
I got everything hooked up.the video is playing
Hello... sorry to hear you are having a problem. There should be a wire on the back of the headunit that is marked "brake". This wire is usually green or pink. You will need to hook the wire marked "brake" together with the black "ground" wire. This should allow the screen to play without the brake being engaged. If this does not work, let me know and I will give you a sequence route to fix the problem.
20 year car audio/video installer
Bay manager
Dvd player does not show
The green parking brake wire from the Jensen unit needs to be connected to chassis ground. This will enable the viewing of DVDs.
Yellow wire on a jensen
There should be some sort of indication of the wiring on the unit,
sometimes on a label, sometimes moulded into a plastic panel on the
back.
Might be power (+)
