I am leaving you this reset information on your unit. However, if you still do not
receive a full led panel
after wards, you may have blown several
components on your power board and will need to be replaced.
Good luck and I hope this fix works for you,
Resetting your LC3040N
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
Figure 1: Example of the reset button labeling on the LC2600N
Unplug the TV power cord from the power outlet.
Unplug any connected devices (DVD, Set-top boxes, etc...)
Press and hold the TV power button for five seconds.
Plug the TV power cord back into the power outlet and turn on the TV.
Open the on-screen menu to confirm that the TV is responding again.
Turn off the TV and reconnect the devices.
Turn on the TV.
NOTE:
If the steps in this document fail to resolve the issue, the TV may require servicing.
