GE Televison & Video • Uploaded on Sep 30, 2013
You can programme your
remote by below method
Manual code entry
1.Turn
on your television or other electronic component that you want to program
the remote control for.
2.Hold
down the "Code Search" or "Setup" button until the LED
indicator light turns on.
3.Hit
the button for the component that you are programming (TV,DVD VCR, etc.).
The LED light should flicker and stay on.
4.Enter
the 3-digit or 4-digit code that corresponds to the TV or device that you're
operating.The LED light should go off if the code is valid, but will flash if
it is not. Try other codes you have.
5.Try
turning the television or other programmed component off to ensure that the
remote works properly, once the light has gone off.
Auto configuration
1.Turn
on your television or other electronic component that you want to program the
remote control for.
2.Hold
3.Hit
the button for the component that you are programming (TV, DVD, VCR, etc.). The
4.
Press and release the "Power" until the television or other component
turns off while waiting at least 2 seconds between each press.
5.Press
"Enter" or "Save" once the remote has effectively turned
the power off. The LED light will shut off and the remote will now operate the
device.
You can get your codes from below website
http://www.jascoproducts.com/support/universal-remote-codes.asp
Thank You
49 questions posted
588 Questions
237 Questions
99 Questions
101 Questions
91 Questions
