20 Most Recent GE 31GT660 TV Questions & Answers
I have a GE31GT660 TV.
Try unplugging it for 5 mins. I heard its a hard reset...Also you can buy a universal remote for it. The brand of TV should be on it as well as the serial number... Once you have them both you can find out all about it...
5/10/2017 4:38:32 AM • GE 31GT660 TV • Answered on May 10, 2017
42le5400 half screen is white
Check connection wire [LVDS] cable, that connects in between its T'Con and display panel for loose contact at its both end connector sockets. Re-seat it once, and check. Replace this cable, with an identical one. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
12/20/2013 2:46:35 AM • GE 31GT660 TV • Answered on Dec 20, 2013
My tv has half a picture the other half is white
You hereby reports that the one side of the screen do not display picture, and the other side have. Is it seen vertically or horizontally. Will you please provide a detailed description of the fault you see on screen? google.com/+GopakumarGopalan
11/24/2013 5:53:11 PM • GE 31GT660 TV • Answered on Nov 24, 2013
How can I change the picture from envelope to full screen?
change the aspect ratio in the picture settings.
10/16/2012 2:29:19 AM • GE 31GT660 TV • Answered on Oct 16, 2012
What would cause a GE 60GW948 have a very snowy, and now No picture screen
when you say gone out---no light on screen or brightness or what? The snowy picture can be got around in most cases.
6/15/2012 3:36:16 PM • GE 31GT660 TV • Answered on Jun 15, 2012
My television, a jvc 21
Yes.This tv problems it is pretty easily repair,tv have a cold soldering in a vertical IC or around that area.But must have a soldering iron and a roll of solders and know and have some basic soldering skills.Take the tv aparts and turn it on take the plastic end of a screw driver tapping arond a vertical IC or around that area.Find out the vertical IC or around that area.Turn the tv off and resolders that vertical IC or that area,will solved this problems.Or take it to the tvs shops tell them the problems.If they're give u fairly priced for a job.Like about $25-$35 maxs.
8/13/2011 12:57:17 PM • GE 31GT660 TV • Answered on Aug 13, 2011
WHEN I TURN THE POWER
hi, you tv have bad epprom. replace it in same #. good luck!!
6/6/2011 8:52:14 PM • GE 31GT660 TV • Answered on Jun 06, 2011
2answers
My tv all of a
You have bad grounds on your vertical IC. And you have a bad capacitor or two. I don't recall the actual location of the vertical IC location. I would say it may be U4501 location. Resolder the seven pins of this IC. Now check capacitor locations C4505 which is a 35 volt 220 Mf value, and C4506 which is a 63 volt 330 Mf value.Replace these caps as necessary. Then check the solder grounds at the power supply chip U4101, this chip is a switch mode regulator and may become detached from the board. Resolder these 11 pins and be careful not to short the pins with too much solder. Please note the two pins on the right (separated by a missing pin) are soldered together, this is OK. Now for the biggest challenge. You must pull the bottom shield off the tuner (has the RF connection). Yes, this area can produce the horizontal lines you speak of. When removed, you will see about 15 bad solder connections. This area will require great skill to resolder. The solder on the perimeter of this tuner is very difficult to work with, and you do not want to burn off any traces connecting to out side feeds. You could destroy this board. Now inside the tuner area there will be 5 pins or grounds that will need resoldered. Be careful here and not to burn off the small traces leading to other connections. Replace the tuner shield after complete inspection and soldering. In some cases the eeprom, locationU3201, will need replaced. Might not in your case as you say you can still watch TV and the audio is good. I know this is a lot of information, but this TV can be saved. I have repaired many of these. Thanks for asking and show a few hands of support.
3/27/2011 3:41:29 PM • GE 31GT660 TV • Answered on Mar 27, 2011
My TV is only showing
If you are talking about top and bottom, there is a small integrated circuit on the main board , it is called the vert out put IC. You will need to replace it and the 4.7 microfarad capacitor located right beside it.
Please leave feedback
2/21/2011 1:21:00 PM • GE 31GT660 TV • Answered on Feb 21, 2011
My Old 1997 GE 31GT660 was working just fine
Ur girl friend clean around did she unplug the tv.Replug it back later?Bet u she did,that why the tv universal codes is gone.Reprogram ur tv unverisal codes again should solved this problems.Tries push the manual control button channel up like one or two times tv will be in input video again like video 1 or 2.
1/13/2011 3:12:23 AM • GE 31GT660 TV • Answered on Jan 13, 2011
07/2002 Tv model # CM36020S
Shorted Hori output Transistor or Bad starup Capacitor near the FBt flyback Transfomer.
12/15/2010 10:46:18 AM • GE 31GT660 TV • Answered on Dec 15, 2010
Cannot change from video mode
My only suggestion would be to purchase a multi-functional remote that you could program to your TV. Now some remotes have to be programed buy your old remote. That is not what you need. You need the kind that comes with a little book that will list your tv model number and give you a code (usually 4 numbers) to teach it to talk to your tv.
9/20/2010 2:52:54 AM • GE 31GT660 TV • Answered on Sep 20, 2010
T.v. out of focus
On the back of this TV you will find two black potentiometers. The top potentiometer should be the focus. Remember, you want to correct the focus, so you will need to pay attention. The bottom potentiometer is the screen voltage. This one will darken or brighten the picture. Be careful not to turn that one. Find a channel with lettering on it to adjust the focus button [top]. Twist back and forth to receive the best location. You may even press the menu button and focus on them. Try that, give me a few hands and thanks for asking!
9/13/2010 4:01:47 AM • GE 31GT660 TV • Answered on Sep 13, 2010
We unpluged our cable line
It is possible that the connection in the RF pin has come out, Open the PIN and check for a break in the cable central lead copper wire, or the shielded wire. Look if the cable was damaged.
I cannot give the codes but if this helps just try to see if the picture comes. Also when you plug please check if the RF input pin is damaged to the tuner., the cable should work with the earlier memory , since there is no signal the TV tries to look for signal hunting around.
So just check with these tips.
8/23/2010 6:47:18 PM • GE 31GT660 TV • Answered on Aug 23, 2010
My sony shows dim, could it be the picture tube
picture tubes harsly ever go out i have work on curtis mathis tvs from the 70s and their tubes were great most like the leads within the tubes need cleaed in order to do theis take it to you local repair sop an they can burn the filament so that they are bright again.
7/1/2010 1:39:01 PM • GE 31GT660 TV • Answered on Jul 01, 2010
Current value
TV is over 10 years old. Built in 98 or 99 I think... Retailed for around $400.00 then. Now, I'd say $75.00 - $100.00 would be fair if still in new condition.
6/17/2010 3:55:26 AM • GE 31GT660 TV • Answered on Jun 17, 2010
3answers
I have a ge 31gt660
Hello. I had this problem and ended up solving it by purchasing a universal remote made by logitech. J.
6/6/2010 1:37:47 PM • GE 31GT660 TV • Answered on Jun 06, 2010
GE 31GT660 TV Logo
66 questions posted
Top GE Televison & Video Experts
ExpressFiX
ExpressFiX
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • GE Televison & Video
Most Popular Question
tv all
  • Televison & Video
