20 Most Recent
LG FLATRON W2252TQ-PF 22" LCD Monitor Questions & Answers
Lg flatron screen keeps flickering, if i switch it
sounds like a capacitor in the power supply is going. Check caps and look for bulged or leaking component. Most new devices have non filled caps so you may not be able to judge these by a visual check.
Black horizontal lines across entire screen.
Visit the site named 'Electro-help' for
more details. Click this link. View it in
"Timeslide" or "Flipcard" option, which can be selected
from the drop down box menu by the [Sidebar] tag, at the top left corner
of the display window. You can also
click the [Home] tab to see the latest updates. It will make search
easy. There are more than 1350 posts to different brand TVs now. Pull up older
posts there or do a search by type in the Brand Name of your device in
the Search Box, at the top right of the display window.
Power is on but have a red flashing light, I
You need to open LCD case and try to find Power Inverter board. On power inverter board, you can see some of failure caps. Please see picture below for sample of bad capacitor. All failure capacitor must be replace with new capacitor and your LCD will be work fine after that.
Thanks for visiting FixYa. We answer your question for FREE. Please feel
free to click on "YES" button in return. Have a good time...!
Thanks
The screen is black and
Try to see if this works on another computer first, if it does, then it assumes the monitor is ok.
Then as the computer boots up, boot to safe mode by pressing F8 and once in that state, set the display to a mode that the graphics card will support.
If none of the full colour options work, the graphics card may be incompatible, try changing the graphics card.
Hey I have an LG Flatron L1718S screen that work fine for a few weeks then suddenly switch off for a few days ,then switch on again,it's a irritating cycle.Please HELP
- Larry Ng Jul 15, 2021that is just a YEAR 2007 LCD computer monitor, it needs a computer to work. if it fails in a 2nd PC ,
if that test fails,the monitor is bad. (hardward failure, monitor.
the tests are simple,
it fails on 2nd good PC, what can be more simple that test ANY 14 year old monitor on a 2nd good PC.
when dead do this.(test2)
they are all here when dead again use a FLASH LIGHT. (or in UK a low carbon foot print TORCH)<< joking.
https://pcdied.com/monitors_and_screens/...
all monitors older than 2010 do this . (has CCFL inside and that is never fun now)
the cure is newer monitors 2011 to now called LED monitor.s or OLED.
the tubes are cold cathode florescent tubes. (back lamps.) (have 5 classic fail symptoms not just dead)
they are short lived,
laptops and monitors both back then. 20,00hours on the clock and go bad. bank on it.
the 3 failures are CCFL, PSU board, and logic board
#1 is CCFL the all died long ago, on average about year 2003 (07 +5= 12, 2012) at 20,000 yours boom dead.
or intermittent.
PSU is here:
below is logic board.
one of the 3 fail, CCFL tubes dead is like 99%
we retire them if the CCFL test fails. (using bench PSU to test them) but you have non of that so. upgrade
Larry Ng Jul 19, 2021
logic board. (CCFL tubes dead, PSU dead, or logic board dead) and or thermally failing , and bad.
Anonymous Jul 23, 2021
99% of all monitors are all dead. due to those silly low live CCFL back lamps.
or the 2cards inside that can fail too. PSU card +HV CCLF power or the Data card is dead.
99.9% of folks seen these facts, upgrade now.
high voltage inside 600v on the CCFL pins
