20 Most Recent Cobra 75 WX ST 40-Channels Handheld CB Radio Questions & Answers
I get no squelch on my cobra 75 wx. I can't receive when somone transmits near me.
that's normal . If someone near you has more power then you he will walk all over your signal . You just might be doing the same to them.
10/28/2018 6:20:55 PM • Cobra 75 WX ST... • Answered on Oct 28, 2018
Wiring diogram for a cobra 75 wx st mic
www.cbtricks.com has your manual .
3/1/2015 7:48:22 PM • Cobra 75 WX ST... • Answered on Mar 01, 2015
I hooked up my cobra 75 wx,st wires backwords and
can you remove it. If you can then check out the numbers on it if you can. then go to Radio shack and buy another diode.
12/22/2014 12:07:17 AM • Cobra 75 WX ST... • Answered on Dec 22, 2014
Hum on transmit
Poor power supply filtering.
12/1/2014 1:18:02 PM • Cobra 75 WX ST... • Answered on Dec 01, 2014
My cobra 29 lx wont transmit
take it off PA and WX and you might find it does.
12/1/2014 12:26:12 PM • Cobra 75 WX ST... • Answered on Dec 01, 2014
Squelch doesn't work
I could tell you but in the end you have to take it to a tech anyway so have at it.
9/1/2014 3:20:04 PM • Cobra 75 WX ST... • Answered on Sep 01, 2014
Does the modulator box have to be grounded ?
the modulator box should already be grounded through the electrical outlet its plugged into.
9/1/2014 12:59:02 PM • Cobra 75 WX ST... • Answered on Sep 01, 2014
Cobra troubleshooting
These models have all connections going thru the mic cable. to the lil box.. if your getting supply voltage on the pins at the box.. check for a bad mic cord..
8/4/2014 5:19:37 PM • Cobra 75 WX ST... • Answered on Aug 04, 2014
Can't pick up any talk on my cobra 75 ws xt cb radio
Was your antennae set up professionally? You may have a short in the cable or connections or even a bad antennae and/or a bad match. Was it matched with an SWR meter? Have these checked out because it does sound like an antennae or cable/connector issue.
4/19/2014 6:30:21 PM • Cobra 75 WX ST... • Answered on Apr 19, 2014
Blew the diode in the radio but can't find numbers to buy new diode can you help
Crossreference the location on your pcb with the triangle pointing to a line on these schematics http://www.cbtricks.com/radios/cobra/75wx_st/graphics/cobra_75wx_st_sch.pdf
10/25/2011 3:14:11 AM • Cobra 75 WX ST... • Answered on Oct 25, 2011
The vehicle fuse blows when it is powered on?
this could be only two things either the fuse is to low in amps or the protector diode has blown and will need to be replaced
10/16/2011 11:07:49 PM • Cobra 75 WX ST... • Answered on Oct 16, 2011
I get a bleed through in the AM/FM/XM radio in my
check the SWR's if there high they will cause problems .. make sure your coax is 95%or better shielded type and have someone check the swr on the antenna should be free at any good radio shop..
9/25/2011 10:27:38 PM • Cobra 75 WX ST... • Answered on Sep 25, 2011
2answers
Cobra 75 WX ST 40-Channels Handheld CB Radio manual/antenna
Hi - You can download the manual from the link underlined in blue below:
75 WX ST
Other info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
5/30/2011 1:50:54 PM • Cobra 75 WX ST... • Answered on May 30, 2011
Cost to convert to 26meg`s thanks
hello depending on technician about $40
3/26/2011 10:47:05 PM • Cobra 75 WX ST... • Answered on Mar 26, 2011
2answers
When I press the PTT
hi 4fshin you need to check if the cable connection is still fit if not srengthen the cable and it should work if the connection is still strong try to wire it to a new radio stasion and then check if it still doesnt work you need to buy a new one if its work you have a problem with the exit in your machie
12/30/2010 10:18:19 PM • Cobra 75 WX ST... • Answered on Dec 30, 2010
2answers
I am to trasmitt and receive while ignition key is
Hi, my name is John. That noise you hear is probably coming from switch,such as ,seat belt warning,door,light, key switch , exc. Try running your CB wire strait to the battery, and see if it stops. If not, Radio Shack sells a noise limiter that goes in line with your connection, don't know how much. Do you have your noise limiter or noise blanker switch on the radio?...hope this was very helpful....
12/30/2010 5:37:17 PM • Cobra 75 WX ST... • Answered on Dec 30, 2010
Cobra 75 wx st no sound/speaker
Hi, my name is John. try putting a external speaker in back of radio and see what happens, might need to replace internal speaker, or something internal. Let me know, I will post the process here......Hope this was helpful..
11/6/2010 7:09:52 AM • Cobra 75 WX ST... • Answered on Nov 06, 2010
When i try and get a radio check i get no
Well, first of all, it's your radio. The Cobra 75 is about the worst money you can spend. They transmit at about 3 watts and all of Jeep customers have opted for bigger radios and I have gotten them away from the handheld units and they appreciate it. The issue is your antenna, what kind is it, where is it mounted, has it been tuned? let me know.
Dodgem250.com
9/13/2010 5:28:28 PM • Cobra 75 WX ST... • Answered on Sep 13, 2010
I have a model75 wx
Yes that is the problem. You need to get the antenna checked.
8/19/2010 8:48:14 PM • Cobra 75 WX ST... • Answered on Aug 19, 2010
Cb transmit noise
Its just RF feed back, that's normal, try to re-route the coax, or just turn the FM down, o try turning your modulation down....hope this was helpful....
5/29/2010 2:54:44 PM • Cobra 75 WX ST... • Answered on May 29, 2010
Cobra 75 WX ST 40-Channels Handheld CB Radio Logo
28 questions posted
Top Cobra Radio Communications Experts
Mike Cairns
Mike Cairns
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Cobra Radio Communications
Most Popular Question
when press ptt
  • Radio Communications
