20 Most Recent Audiovox D1708 Portable DVD Player Questions & Answers
0answers
0answers
Have lost car adaptor & rechargeable battery pack for D1708
Talk to a repair man.
11/6/2013 5:51:18 PM • Audiovox D1708... • Answered on Nov 06, 2013
Disc will not spin
Make sure the connections are seated properly. Dirty disk? Older device, has it ever worked? The laser in the device may have malfunctioned. If this is the case, replace the device. New device? Go to manufacturer.
4/4/2012 1:53:50 PM • Audiovox D1708... • Answered on Apr 04, 2012
When i load a disk it sayd loading then it says no disk
Grab a Q-Tip and rubbing alcohol, gently clean laser lens and allow several minutes to dry, if this fails! it is cheaper to replace the player.
3/7/2012 6:22:45 AM • Audiovox D1708... • Answered on Mar 07, 2012
2answers
Not playing the dvd
NO DO NOT WATSE YOUR MONEY PLEASE READ THIS! Ok I have owned the same portable dvd player for a few years now , and every know and then it acts up and wont play anything only to say " NO DISC " . What I have found over time is to fix this , turn it upside down , and slam it with your fist , enough for a sligh punch . This may sound really stupid but trust me it works great , just dont slam it so hard that you break , and this has worked for me numerous times , good luck :)
9/19/2011 3:31:46 PM • Audiovox D1708... • Answered on Sep 19, 2011
I place dvd disc in. I close the cover then in
I would advise you first to clean the laser / lens with a clean cotton bud moistened with alcohol.
To be honest with you, this would be the first remedy for a user before having this unit repaired by a certified technician.
You will need to open the cover of your device. You will find the mechanical loading disc. The one where disc is loaded. In the middle of the mechanical loading you will find a spindle motor and beside this is a small glass illuminating red when the unit is on, this is the lens. Clean it with a cotton bud moistened with alcohol.
7/18/2011 11:12:00 PM • Audiovox D1708... • Answered on Jul 18, 2011
I have this model and haven't used in over a
shock the batt wid 12volts dc...put back in the player...recharge then
6/3/2011 4:17:16 AM • Audiovox D1708... • Answered on Jun 03, 2011
I have great sound on my Audiovox portable dvd
  • Check that the A/V IN/OUT Switch on the side of the player is set to the OUT position.
  • Check the small switch near the hinge at the back of the unit, if one is installed there. It turns off the LCD screen when the panel is closed. This switch sometimes sticks in the down position and the screen remains off. When the screen is opened, the switch is supposed to pop up. If it is still in the down position, try to free it with the ends of a toothpick or paper clip.
  • If both switches are correctly set and the screen remains blank, the unit should be sent to Audiovox for service.
5/16/2011 1:18:22 AM • Audiovox D1708... • Answered on May 16, 2011
When charging does blink light
Hi saaaved90,
Yes, the blinking means that it IS charging.
5/10/2011 5:48:21 PM • Audiovox D1708... • Answered on May 10, 2011
3answers
Can this be fixed?
i have an audiovox dvd player model D1718 . i put the disc in and it says it is loading but then comes up no disc . how can i fix this problem?
3/27/2011 1:32:03 AM • Audiovox D1708... • Answered on Mar 27, 2011
Service center for portable
If you take a look the the following Audiovox link, and enter your model number, it should be able to find a service center near you. Alternatively there is a link there to contact Customer Services who would be able to advise you by email.
http://voxrightnow.custhelp.com/app/answers/detail/a_id/4956/~/audiovox-portable-video-products-repair-centers-and-warranty-info
3/21/2011 6:10:25 AM • Audiovox D1708... • Answered on Mar 21, 2011
Audiovox D1708 Portable DVD Player Logo
83 questions posted
Top Audiovox Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Audiovox Televison & Video
Most Popular Question
place dvd disc in close cover in
  • Televison & Video
