20 Most Recent
Audiovox D1812 Portable DVD Player Questions & Answers
Player stays in loading mode never finishing and playing the dvd
see the causes and fix it: God bless you
- No disc. - Load a disc into the
tray.
- Disc has been loaded upside
down. Place the disc with the label side up.
- Disc region code does not
match region code of the player.
- Disc type is not the correct
type to play.
- Disc is damaged or dirty.
Clean the disc or try another.
- Moisture may be condensed
inside the unit. Remove the disc and the leave the power on
for one or two hours.
Clean with disk cleaner the Lens +OPU
Battery is not charging
Check the voltage and currrent factor of the battery charging circuit. Use a multimeter in voltage during charging and in series to the battery using a jumper to see the current to the battery. If the charge voltage currrent is good then the battery is faulty , if not the charging circuit must be checked.
Audiovox D1812 Portable DVD player won't recognize disc
I have the same model, exhibiting the same problems. I bought it in 2005, and have used it only on trips. I bought mine at Sam's club and I emailed them and Audiovox and have gotten no response. It says little of Sam's Club or of AudioVox!
MY dvd player has power coming to it and turns the
your best bet is to try and thoroughly clean out the lens area. If you can purchase a can of air and use that from a 10 inch distance, Any closer could be damaging to your optical carriage most of the time it's just dust that accumulates.
My daughter has an Audiovox D1998 model and isn't
Try a CD disc lens cleaner (can be found at Radio Shack, Wal Mart, Best Buy). Is it still under warranty? If not try your local TV repair shop for an estimate. But beware most shops do charge a diagnostic fee to look at the equipment. Note: Since these units can be found on the net for about $100 you may come out better with getting a new one.
