20 Most Recent
Audiovox SP11CDP 10-Disc CD Changer Questions & Answers
Code needed to activate head unit for eurovox 10 cd stacker
The pin number is usually in the vehicle manual. Visit the wreckers to see if the standard manual was in the car and just check that. other than that you might need to contact holden with the vin number of the car etc to get the unlock code. that is the vin number of the car it came out of. If you cant get that i am sure that they wont unlock it for you as it will be presumed stolen. If you cant get the code from holden, take the stereo back as its going to be an expensive paperweight
Where is the changer fuze located on an autdiovox
It's not a fuse. More than likely it tried to load 2 discs into the same slot and jammed. That's one of the most common problems with shangers. If you pull the unit out of the vehicle and open the top you will see how it's jammed. Lightly move the CD towards the tray side, not into the cartridge, then plug the unit back in. It will reset itself and then you can eject the cartridge. Then inspect the cartridge for warps or cracks. You may want to replace the cartridge, they do wear out. Also, a good habit is to run a Laser lens cleaner thru the unit itself 3 or 4 times a year to keep the lens clean. It's really the only maintanance you can do. Hope this helps
I need help!
HI THERE I JUST PURCHASED EUROVOX RADIO WITH 10 CD STACKER FROM EBAY BUT THEY NEVER SUPPLIED ME THE CODE TO ACTIVATE THE UNIT BOUGHT IT OF COMMODORE WRECKER IN SUNSHINE VICTORIA CAN YOU HELP PLEASE
Replacement disc magazine
manufacture of make of cd changer but it would be cheaper to buy new cd changer i would think but worth you checking
My Clarion 6cd changer Say's Err #9 ?
This means Weak Radio Frequency.... try changing the radio frequency, and you should have no problems :D.... Please rate answer... and i wish you the best of luck, because i know from experience that audio equipment is not cheap... ask questions if you have anymore :)
What are the input wires on a audiovox amp777
The Audiovox AMP777 is a 4-channel power amplifier, and the input wires will depend on the audio source you are using. Typically, the amplifier will have RCA input jacks for left and right channels, and you would use RCA cables to connect the audio source to the amplifier. Some amplifiers also have a high-level input option, which would allow you to connect speaker wires directly to the amplifier's input terminals. However, it's always best to consult the user manual or contact Audiovox support for specific wiring instructions for your amplifier model.
