20 Most Recent Samsung Digimax A400 Digital Camera Questions & Answers
2answers
Camera is blurry when taking photos
Use a tripod or set your camera to a higher shutter speed.
6/17/2021 7:29:56 AM • Samsung Digimax... • Answered on Jun 17, 2021
0answers
I have a message on my digimax A400 screen stating
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
3/1/2013 4:10:08 PM • Samsung Digimax... • Answered on Mar 01, 2013
How to run the camera
You may download a copy of the manual here.
3/1/2013 4:09:22 PM • Samsung Digimax... • Answered on Mar 01, 2013
Impossible to format my new memory card 4GB (chart
The A400 works with MMC and SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
3/1/2013 4:08:32 PM • Samsung Digimax... • Answered on Mar 01, 2013
Help me
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
3/1/2013 4:07:48 PM • Samsung Digimax... • Answered on Mar 01, 2013
4GB SD d'ont work, card
3/1/2013 4:06:48 PM • Samsung Digimax... • Answered on Mar 01, 2013
I can't get the camera to get out of cassette standby. I have the setting on camera, but it stays in standby.
I think I just answered this but it will require a trip to the shop. No user fix.
1/25/2013 7:14:50 PM • Samsung Digimax... • Answered on Jan 25, 2013
Lost my APPLICATION SOFTWARE FOR Digimax S800 camera
You don't need any software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
11/21/2012 9:23:43 PM • Samsung Digimax... • Answered on Nov 21, 2012
I need a user manual for samsung digimax d 73
Hello, Try searching the name and model of your camera on the web theiris some free ones out there.
10/10/2012 9:33:55 AM • Samsung Digimax... • Answered on Oct 10, 2012
Samsung + digimax A400 + how to put into movie mode
You may download a copy of the manual from here. The recording instructions begin on page 19.
5/25/2012 5:15:28 PM • Samsung Digimax... • Answered on May 25, 2012
USER MANUAL FOR SAMSUNG A400 DIGITAL CAMERA
Please find the manual from the link below:click on:Samsung A400
10/30/2011 3:21:19 AM • Samsung Digimax... • Answered on Oct 30, 2011
I have a Casio Exilim
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out (note 2GB or less standard SD cards. These are very inexpensive these days, and are available on Amazon if your local store no longer carries them). There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
9/18/2011 6:10:18 PM • Samsung Digimax... • Answered on Sep 18, 2011
We have a Digimaz A400
Having gone over a month without a response to my query, I assume my suggestion to use a card reader eliminated the need for a driver.
6/29/2011 4:32:02 PM • Samsung Digimax... • Answered on Jun 29, 2011
Download software for Samsung digimaxA400
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as the free Picasa ( http://picasa.google.com ).
5/18/2011 4:47:59 PM • Samsung Digimax... • Answered on May 18, 2011
When you turn it
This usually happens when the wrong type of card is inserted. For example, your camera takes SD cards. If you try to use an SDHC card, the camera cannot work with it and just stalls.
5/10/2011 8:26:23 PM • Samsung Digimax... • Answered on May 10, 2011
Lost instal disc for samsung a4 digimax camera
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
4/21/2011 5:27:32 PM • Samsung Digimax... • Answered on Apr 21, 2011
Samsung Digimax A400 Digital Camera Logo
75 questions posted
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
DigiMax Samsung
  • DigiMax Samsung
Most Popular Question
message digimax a400 screen stating
  • Cameras
