20 Most Recent Samsung Digimax 401 Digital Camera Questions & Answers
What should be the memory card size to be inserted in samsung digimax 401
The 401 takes MMC and SD cards, 2GB or smaller.
10/6/2014 5:18:24 AM • Samsung Digimax... • Answered on Oct 06, 2014
When I put a 4gig mmc into my samsung 401 digimax the green led light flashes repeatidly and i am un able to use any function. when on its own 16gig internal memory it works fine
If you look at the user manual you will see that it only has 16meg internal, not 16gig as you stated.It says this: Internal memory:16MB flash memoryExternal memory: SD card /MMC (Up to 256MB guaranteed)So it probably can't take a 4 gig card.
1/23/2012 8:07:48 PM • Samsung Digimax... • Answered on Jan 23, 2012
Lost disc camera driver
Try NOT using a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
8/17/2011 9:22:44 PM • Samsung Digimax... • Answered on Aug 17, 2011
I have a samsung digimax 401 digetal camera but i
Does the camera have a removable memory card? Could the card be put into a card reader connected to your computer via the USB port?
3/4/2011 10:29:34 AM • Samsung Digimax... • Answered on Mar 04, 2011
Cant get the memory card in and when i take it out
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
12/17/2010 11:06:53 PM • Samsung Digimax... • Answered on Dec 17, 2010
Memory card error
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
11/23/2010 6:23:26 PM • Samsung Digimax... • Answered on Nov 23, 2010
How do u delete pictures
first go to play mode select your picture which you want to delete.there is one logo look like recycle bin press then asked delete yes or no select yes.your picture will be deleted.
10/22/2010 6:07:25 PM • Samsung Digimax... • Answered on Oct 22, 2010
What is the maximum gb card for a samsung 420
Your camera is definitely compatible with SD cards up to a maximum capacity of 512MB. It was never hardware tested by the manufacturer with larger capacities and definitely cannot accept any SDHC cards (4GB and upwards); I have also tried one in the past with a 2GB SD card and it was unusable. Unfortunately Samsung have never actually published any hard and fast data stating what the maximum capacity is for the Digimax 420.
In summary then, you're good to go with 512MB SD, 1GB SD is a gamble and will either work or it won't (but won't harm your camera or the card), 2GB and above are not suitable.
10/11/2010 8:37:35 AM • Samsung Digimax... • Answered on Oct 11, 2010
New 2 gig s d memory card will not format keeps
Hi
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • 8/27/2010 8:10:18 PM • Samsung Digimax... • Answered on Aug 27, 2010
    I lost disc with driver for samsung digimax
    Forget the disc. Use a separate card reader to download your pics.
    7/6/2010 2:02:54 PM • Samsung Digimax... • Answered on Jul 06, 2010
    When I take a picture is ok if I ma watchin on
    check settings in ur camera . . .. if confused reset setting to factory default
    5/24/2010 6:48:49 AM • Samsung Digimax... • Answered on May 24, 2010
    2answers
    Is San Disk memory card compatible with Digimax
    SD Memory Card is compatible with your Digimax 401 camera. You just need to format the card.
    Formatting a memory card
    ** This is used for formatting the memory card. If you run [FORMAT] on the memory card, all
    images, including the protected images, will be deleted. Be sure to download important
    images to your PC before formatting the memory card.
    ** If the memory card is not inserted, the internal memory will be formatted.
    ** Be sure to format the memory card if you are using a newly purchased or non-initialized
    memory card, if it contains data that the camera cannot recognize, or if it contains images
    captured with a different camera.
    Formatting a Memory Card
    1. In any mode other than Voice Recording mode, press the MENU button.
    2. Press the LEFT/ RIGHT button and select the [SETUP] menu tab.
    3. Select the [FORMAT] menu by pressing the UP/ DOWN button and press the RIGHT button.
    4. Select a desired sub menu by pressing the UP/ DOWN button and press the OK button.
    - If [No] is selected : The memory card will not be formatted.
    - If [Yes] is selected : A [PLEASE WAIT!] message appears and the memory card will be formatted. If you ran FORMAT in Play mode, a [NO IMAGE!] message will appear.
    4/12/2010 6:01:06 PM • Samsung Digimax... • Answered on Apr 12, 2010
    Sir...,
    You just need to format the card in the camera. This will completely erase it so download any pics first using a card reader if necessary.
    2/18/2010 3:26:16 PM • Samsung Digimax... • Answered on Feb 18, 2010
    My camrra is digimax u-ca401 and iget lenserror
    Fixing a Lens Error on a Digital Camera
    This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
    The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
    A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
    Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
    The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
    Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
    Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
    Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
    Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
    Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
    Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
    Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
    Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
    1/14/2010 8:14:12 PM • Samsung Digimax... • Answered on Jan 14, 2010
    I have forgotten how to set the timer
    hi there
    if you look at the central control button, there is a multi function button at 3 o'clock.
    i think it has 5 functions, one of which is the timer option.
    hope this helps
    beergut707
    12/2/2008 9:58:14 PM • Samsung Digimax... • Answered on Dec 02, 2008
    2answers
    Will not turn on
    Comment by The Fixx, posted on Oct 31, 2007
    And here is the solution... Eureka - we have found a cure. Internal memory of 16MB is shot. Buy a memory stick, insert and voila.... The camera is back too life. And apologies to Samsung....This is really an extrodinary little camera.
    9/14/2008 2:41:14 PM • Samsung Digimax... • Answered on Sep 14, 2008
    USB CABLE
    You can get one from any computer or electronics shop.
    3/16/2008 9:28:20 AM • Samsung Digimax... • Answered on Mar 16, 2008
    Status LED just blinking the whole when switched on
    I have lost all confidence in this model camera. If you managed to take at least 500 pics - consider yourself lucky. Even the experts are baffled by this problem. Time for a new camera BUT not a Samsung I"d say.
    10/31/2007 3:02:43 PM • Samsung Digimax... • Answered on Oct 31, 2007
    Samsung Digimax 401 Digital Camera Logo
    Popular Tags
    28 questions posted
    Top Samsung Cameras Experts
    ZJ Limited
    ZJ Limited
    Are you a Samsung Camera Expert? Answer questions, earn points and help others
    View Most Popular
    DigiMax Samsung
    • DigiMax Samsung
    Most Popular Question
    when put 4gig mmc into samsung 401
    • Cameras
