20 Most Recent
Belinea 1930 S1 Monitor Questions & Answers
How to switch from analog to digital mode
Any contemporary monitor is able to switch analog/digital mode automatically if connection from signal source to monitor is set up properly.Connect digital output from your graphic card to DVI input of the monitor. Disconnect any other signal cables from monitor and switch on both devices (PC & monitor). Wait a while. Monitor checks its inputs and a activates digital DVI, because it is only one active input on it.If none picture excluding error message of monitor is displayed, go through these steps:1) Check whether your monitor is set for automatic input selection. If monitor buttons have no response try to use analog input to activate screen (any picture, desktop background...) and then get monitor menu access by pressing menu button.2) Find out what connector type has your graphics card in PC. Possibilities are: DVI, HDMI, DisplayPort and some their options. See Wikipedia for connector look if you are not sure.Remember that blue D-SUB (VGA) connectors are analogue and you cannot activate digital mode through analog VGA cable.3) Use appropriate cable to connect monitor to PC.Example: Your PC has HDMI output. Use HDMi-to-DVI cable. Your monitor input is DVI and common DVI-DVI cable is not suitable in case you have PC with the HDMI.Note that DVI-to-DVI, DisplayPort-to-DVI etc. cables are available. You must buy right one.Be aware that "Auto" button is inactive in digital mode of monitor.
Lcd screen damaged needs replaced
If the screen has a cracked screen - then the LCD display needs to be replaced, but if it has a backlight problem then the fault could be the inverter or the CCFL lamp. These components are cheaper to replace instead of the whole screen.
Check out LCD parts for parts, service and DIY info. Use this link :-
www.lcdparts.net
9/10/2009 4:30:09 AM •
Belinea...
Answered
on Sep 10, 2009
Wireless not working
Make sure the wireless pickup for the laptop, integrated or separate is installed properly and is enabled. The laptop should have a function key (check your manual) like "FN". Pressing this key and usually a function key (F1-F12) should tell you if the wireless function if built in is enabled. If the wireless pickup is USB or a PCMCIA, check the installation again and make sure the hardware is compatible with each other. It's usually not a good idea to mix vendors like using a Linksys router with a Netgear pickup.
8/23/2009 11:14:53 PM •
Belinea...
Answered
on Aug 23, 2009
How i can get Erasmus Mundus Scholarship?
1. RESEARCH: FIRST, RESEARCH THE ERASMUS MUNDUS PROGRAMS AVAILABLE AND FIND THE ONE THAT SUITS YOUR FIELD OF STUDY.
2. APPLICATION: FILL OUT THE APPLICATION FORM COMPLETELY AND ENSURE YOU PROVIDE ALL REQUIRED DOCUMENTS.
3. ACADEMIC RECORDS: MAKE SURE YOUR ACADEMIC RECORDS ARE STRONG AND HIGHLIGHT ANY RELEVANT EXPERIENCE OR ACHIEVEMENTS.
4. LETTERS OF RECOMMENDATION: GET STRONG LETTERS OF RECOMMENDATION FROM PROFESSORS OR EMPLOYERS WHO KNOW YOUR WORK WELL.
5. ESSAYS: WRITE STRONG ESSAYS THAT SHOWCASE YOUR PASSION, MOTIVATION, AND GOALS FOR STUDYING ABROAD.
6. LANGUAGE PROFICIENCY: IF REQUIRED, TAKE LANGUAGE PROFICIENCY TESTS LIKE IELTS OR TOEFL AND SCORE WELL.
7. INTERVIEWS: BE PREPARED FOR INTERVIEWS IF NEEDED AND SHOW YOUR ENTHUSIASM FOR THE PROGRAM.
8. DEADLINES: MAKE SURE TO SUBMIT YOUR APPLICATION BEFORE THE DEADLINE.
I have a problem with
dear ap inpage ka ye version download karen or is article ko parhain Apko Zaroor Faida hoga.
https://infotechinurdu.blogspot.com/2017/09/how-to-download-inpage-urdu-inpage-free.html
Panamax 1000+
Can you please advise what is the panamax 1000 the only panamax I now is for headaches!
