20 Most Recent
HEWLETT-PACKARD Pavilion dm4-1265dx Notebook Questions & Answers
HI,
My web cam is not
A lot of people seem to have this problem. By default the webcam should be off and only activates when you use the software like skype or youcam. Try loading those programs to see if you can use the webcam. If you cannot then it could be a driver or hardware issue - you can download up to date drivers from http://www8.hp.com/uk/en/drivers.html
Put phone and usb cord in the lap top to
The flashing orange light could be the indicator to tell you that your wireless adapter is working and has a connection to your
router, if you are not wireless, press the button that is flashing and it will disable your wireless connection,to turn back on press it again.
Or there is another smaller orange indicator which tells you you are runing on battey and it is in need of charge
My hp dm4-1265dx wont boot,
Try the System Diagnosis mode by pressing ESC when turning the laptop on, and the Hard Disk test fails every time, showing the following results: This will check if you have a hard disk problem.
Then get back to me!
90B fan error
Start your notebook and start tapping the F2 key. In the diagnostic screen perform the hard disk diagnostic. If the diagnostic reports a hard disk smart test fail, then your hard disk is failing and must be replaced. That is the only way you will be able to return your notebook to useable condition.
If hard disk is ok I suggest you goto HP support Forums at
http://h30434.www3.hp.com/t5/Notebook-Lockups-Freezes-Hangs
Freezes wile typing
Restart or get off programs that seem to make it freeze a lot. Try to restart it and when it does shut it down and start it back up. Then restart it again.
Fingerprint
Use the fingerprint to log in, open the user application in the control panel and change your password.
Applications won't open up
Have you updated your antivirus and antispyware software on your computer? It seems like you might have spyware on your computer. Run a full scan on your computer with both software and see if it helps.
Laptop mousepad doesn't work correctly
If it is a new Laptop then I'll not suggest you to open it for cleaning because you'll void the warranty period. You can check for the latest touch pad driver and update it once. it may help you.
I cannot locate my bluetooth on hp pavilion dm4 1162us
Hi ,You'll find bluetooth in the control panel . providing your operating system offers it .and unless its built in to your computer , it takes a bluetooth usb adapter let me know if this helps you , and i will advise futher ..............Goodluck Roy
