20 Most Recent
HEWLETT-PACKARD Compaq Presario CQ56-129NR Notebook PC Questions & Answers
How long for new battery to charge full
maybe 6-8 hours. for sure overnight. If it does not charge fully in 12 hours, there is a problem. It might be the connection between the charger and motherboard if the laptop is old
How can i put hdd out of ibm t40 in compaq cq56?
The T40 is a ten+ year old machine. The hard drive in there will not fit in the newer computer, its of an older type no longer supported. Your best bet would be to get an external USB enclosure that supports IDE drives. If the drive has actually gone bad, you'll need a program like getdataback to recover your files.
0xcooooooe error
This error may occur if the registry entries and the drivers for the mass storage controller hardware in the backup computer are not installed in Windows. Download any reliable program like I always use Reginout to fix such errors by using its Repair Registry feature. And update drivers.
Reformat partition
there are a lot of free format tools on line choose one and reformat the partition. but it you have the installation disc there is the format tool on that.
Dvd player not working
have you cleaned the laser. they do need a clean every now and then. cotton bud does the trick with some lazer cleaning fluwid on it
Compaq pressario start up problem
you need to do a scan disc in tools for the hard drive. it need to be set to auto fix and it will then say it will start on next startup. shut down and restart and just leave it to do its stuff. it should fix it. failing that you need a system monitor system installed like winfix that can detect windows faults and fix them.
My laptop is not starting up
take the battery off unplug ac, hold down the power button for 30-60 seconds put power ac on not battery press power if comes on dont put battery on till windows screen comes on make sure you dont knock out the ac while doing this.
