20 Most Recent
Epson Workforce 520 Printer Questions & Answers
Im getting an error "see my documentation" on my
I had this issue and contacted epson support. They had me open the top to access the cartridges and physically slide the cartridge from its resting place over to the other side and and there was a small piece of paper that got caught in a print and was between the the ink and the cleaners. I then needed to physically move the cartridges back to the resting place and then close the top. Then on the printer, go to the menu and clean the nossels and the test the cartridge. if the lines are broken at all or you dont see words at the top of the test page, then clean the nozzles again. complete this and print a test page or copy. I was good to go.
Epson workforce 520 won't recognise ink cartidges
When replacing ink on the Epson Workforce 520, Ensure the cartridges have the correct/same number of gold contacts. Ive seen them with 7 and 9 gold square contacts and they were otherwise identical, and the ones with 9 contacts threw an "cartridge not recognized" error on the printer's dispay.
Why can't I get "maintenance" on printer menu?
Hi, try the following:
Turn the printer off and wait a few seconds, then turn the printer back on.
Push Menu.
Push the arrow down key to get to "Maintenance"
Trust this helps, regards Alan
When I try to print
simply check if there is some part of paper stuck inside also you should clean it from dust weekly or when its need
