20 Most Recent
Kodak EasyShare M532 Digital Camera Questions & Answers
Blurry pictures
A common problem is a finger print on the lens. If needed, clean the lens with a microfiber lens cloth. Commonly available with spectacle cleaning kit. Did you drop it? Are you actuating the shutter by "squeezing" the button and not pushing on it, moving camera around? Try using a shaky hand setting, often indicated with a hand icon and wavy lines, indicating movement.
My nikon camera says lens obstructed what do i do
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.And here's a video summary of the steps:
Need kodak m532 software
You don't need any special software. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as
Picasa.If you really want the Kodak software, you may download it
from here.
