20 Most Recent
JVC Everio GZ-HM650 Camcorder Questions & Answers
Hi, please help me! i have a JVC HD everio
Your camera has a removable SD card in it to record your video. If your computer has a card reader built in the you simply insert the SD card from the camera to the reader and transfer the files to your PC. If your PC doesn't have a reader, they can be purchased on line or Walmart or any camera supply store for anywhere from 3 to 6 or more dollars.
I recently purchased
The video files are encoded in AVCHD so you will need a program to import the videos from the camera, not just open the raw video files from the camera. There is probably a software CD or download link that was included with the camera, find that and use the software that it comes with to import the video to your computer. If you have a program like iMovie, Windows Movie Maker, or Final Cut Express, those should all recognize the video when you connect the camera or memory card. You can use one of those to import and edit your video, as well.
Power not on or USB device not compatible
I think your battery is 100% OK, if the power supply is perfect there may be problem with the switch, clean it with contact cleaner spray often press the switch several times.
if the switch contacts are not connecting, this will help it to clear it.
open the cam, check the power supply on the main board, there is a
small fuse on the circuit board test it with. eventually we have to suspect the mother board. if so should change it.
I can not access the menu on my jvc everio gz-mz37u to reformat the hard drive and HDD error is still showing, please help.
first of all my advice is: if you keep any electronics devices without usage for a long period, you must detach the battery/power supply.
in this case I think the hard disk may be faulty, if you can open the camera and takeout the HDD connect with an HDD dock connect the dock to your system, in normal condition your computer will detect the hard disk, if so you can save the contents to your computer or you can format it, if it is not detecting your computer it means the HDD is physically damage. please change it.
Everio media browser 3 be
I solved my problem by changing the setting from PAL to NTSC in the Everio media browser (the unit was purchased in the US but the software was set to PAL).
