20 Most Recent Sub-Zero 650 / O Bottom Freezer Refrigerator Questions & Answers
Sounds like the gear is failing in the ice maker unit. I would replace it.
Sub-Zero 650 / O... | Answered on May 31, 2019
I fixed my leaking problem by pulling out the vegetable drawer and checking the condensation drain hose. Sure enough, it was clogged and the condensation had nowhere to go but move out toward the front of the fridge, down the left side and onto the floor. Once that drain hose was cleared (with a bendable straw), no more leak!
Sub-Zero 650 / O... | Answered on Feb 09, 2019
Turn the refrigerator off for a minute to reset the vaccum condenser light.
Sub-Zero 650 / O... | Answered on Oct 17, 2018
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Sub-Zero 650 / O... | Answered on Nov 22, 2017
Your condenser fan motor should run any time the unit is calling for cooling, if the compressor is running, the condenser fan should also be running.
Hope this helps....GOD BLESS....Randy....
Sub-Zero 650 / O... | Answered on Nov 07, 2017
switch the fridge off and try warming the ice maker workings up with a hair dryer.
Sub-Zero 650 / O... | Answered on Jul 11, 2017
It sounds like either an airflow issue, like dirty or restricted coils, or a fan not working well. Or it may be low on charge.
Sub-Zero 650 / O... | Answered on Jun 09, 2017
Freezer door frames have a small heating element in them to stop that happening. Your element is failed.
Torn gasket seals just cause frost inside, but also cause the compressor extra stress if the seal is bad. This causes the compressor to keep running as yours does. They are cheap to buy and easy to fit.
With a 12 year old one, it is probably time for a new one. The new ones are more energy efficient and are cheaper to run.
Sub-Zero 650 / O... | Answered on Mar 23, 2017
Different connections but this is the same freon.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Sub-Zero 650 / O... | Answered on Aug 20, 2016
Control panel lights are behind the panel, so if the compartment lights are on the panel is lit. If no lights are on when you open the door, check your door switches as you may find the light switch has failed. Look there first, no lights, possible just a bad switch.
Good Luck
Sub-Zero 650 / O... | Answered on Feb 02, 2016
Check you your drain line behind the 2 bottom drawers. Most likely it's clogged. You can try snaking it out with a single foot wire. See if the water goes away from the trough.
Smith Brother Appliance Repair reviews
Sub-Zero 650 / O... | Answered on Jan 30, 2016
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
671 questions posted
Top Sub-Zero Refrigerators Experts
John Tripp
John Tripp
louis_benton
Level 1 Expert
DOUG DYKAAR
DOUG DYKAAR
Level 1 Expert
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Sub-Zero Refrigerators
Most Popular Question
subzero 650 drip tray full water factory
  • Refrigerators
