20 Most Recent
Dell All-in-One Multifunctional (v715w) InkJet Printer Questions & Answers
Dell V715w all-in-one print job stuck in que
If you have Windows OS, try this:
Clear Printer Spooler files and enable the Spooler service.
a. Click Start, type "services.msc" (without quotes) and press Enter.
b. Double-click "Printer Spooler" in the Services list.
c. Click Stop and click OK.
d. Click Start, type "%WINDIR%\system32\spool\printers" (without quotes) in the search box and press Enter. In the open window, and delete all files in this folder.
e. Now, go to “Services” again. Double-click "Printer Spooler".
f. On the General tab, next to Startup type, make sure that Automatic is selected.
g. If the service is not already running, under Service status, click Start, and then click OK.
Hi, Go to your search programs and files box in the start menu and type in services when you open services scroll down to Print Spoolers double click and you will see service status started hit the key that says stop after it stops hit OK to close it and reopen Print Spoolers and click open tab and then hit OK to close then close services box and you should be able to print again.Good Luck
I just got a new
Try performing a head clean using the printers software maintenance tools, the only problem with that is it normally uses all of the ink in the cartridges, I get cheap ink cartridges http://www.dinkycartridges.co.uk
Dell V715w wont receive faxes
To receive a fax automatically:
- On the printer control
panel, press the Setup
button,
then use the menu to select Fax
Setup, Ringing and Answering,
and then Auto Answer.
- Select On and then press OK
to save the settings.
- Select Pick Up On and set
the number of rings, then press
OK to save the settings.
To receive a fax manually:
button,
- Select Off and then press OK
- When the telephone rings and
you hear fax tones when you pick
up the handset, press the Start
button on the printer or *9* on
the telephone attached to the
printer.
Put new cartridges in and
Hi jsnorris,
Most of the time this problem is a print head issue. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, please follow the steps below.
1. Open the printer and wait for the carriage to slide over. If for some reason it does not follow these instructions:
2. Unplug the printer
3. Manually slide the carriage over until you can get the ink cartridges out.
4. Remove the ink cartridges from the print head.
5. Use cotton swabs dipped in hot water or a mix of hot water and isopropyl alcohol to thoroughly clean the print head.
6. Repeat this until there is no ink residue coming off on the cotton swab.
7. Once finished, allow to dry and replace the cartridges
8. Try to print something now
If that does not fix the problem then you have one of two possibilities:
1. One of the ink cartridges is defective and causing the error.
2. If it's not that, then the print head will need to be replaced.
Hope it helps.
Thank you for using FixYa.
