20 Most Recent Dell 5130cdn Color Laser Printer Questions & Answers
2answers
HOW DO i COLD RESET A 5130?
  • Connect the USB cable from the printer into the computer. Click "Start," "Search," "For Files or Folders." Click "All files and folders," and search for the folder "UAN." Double-click the "UAN" folder. Then go to the "System Utilities" folder within it. Double-click the "Reset Dell Printer" icon
12/29/2019 6:58:46 AM • Dell 5130cdn... • Answered on Dec 29, 2019
2answers
My school room printer Dell 5130cdn is out of color ink, however it does still have black ink, how can i get the printer to print with just the black ink?
when in print section go to settings and click on black or unclick color be aware that color is need to get black and white reproductions ( copies)
11/4/2019 5:19:50 AM • Dell 5130cdn... • Answered on Nov 04, 2019
No panel lights other than a blinking yellow light at top right.
Did you ever get this figured out? I am having the same issue :(
5/19/2016 12:45:36 AM • Dell 5130cdn... • Answered on May 19, 2016
Reset fuser message on dell 5130
Johnathan, Reset the life counter:
  1. Enter the printer's tech mode by quickly pressing the sequence of keys Menu > Up Arrow > Left Arrow > Tick > Right Arrow > Cancel > Menu. If tech mode does not appear, Re do key sequence again as quickly as possible. A delay in pressing the keys will stop the menu from opening.
  2. Select tech menu , data setup, Clear fuser count.
  3. Restart the printer.
  4. Check the attached links,instruction and guides, Good luck "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Knowledge Base Replacing the Fuser on Dell 5130cdn Laser Printer https://www.sosnfl.com/wp-content/uploads/2014/12/Dell-5130cdn-Users-Guide.pdf
4/9/2016 10:41:52 PM • Dell 5130cdn... • Answered on Apr 09, 2016
I am blue streaks that in some places look like colour leaks when priniting in colour. I tried using the felt cleaning tool and there is no improvement.
If you are getting cyan streaks then likely the cyan cartridge is leaking. Try a new cyan cartridge.
3/20/2015 3:55:10 PM • Dell 5130cdn... • Answered on Mar 20, 2015
Dell 5130cdn prints pictures slow, how do I fix it?
Dear The time taken to print a picture depends up on its size, resolution,quality, paper standard. the quality may reduce to normal or draft also resolution, This may produce less quality image. However the paper standard may not reduced as it require the proper temp. to fix the image on paper. Thanks.
2/26/2015 6:12:51 PM • Dell 5130cdn... • Answered on Feb 26, 2015
How to cold reset a dell 5130 printer?
Hi I think by a "cold reset" you mean returning all the settings to their factory default settings. However rather than just tell you to do this (in case you mean something else) I give below the link to the Dell website which has the machine's user manual in pdf format which can be saved to your computer and perused at your leisure to make absolutely sure you use the "reset" that you want. http://downloads.dell.com/Manuals/all-products/esuprt_printers_main/esuprt_printers/dell-5130cdn_User%27s%20Guide_en-us.pdf Hope this helps Cheers
11/7/2014 8:26:41 PM • Dell 5130cdn... • Answered on Nov 07, 2014
Is there a way to get rid of horizontal streaks?
1) Inspect, clean and reinstall print cartridge. 2) replace the print cartridge 3) Replace the charge roll assembly. Some call this the fuser assembly.
8/16/2014 1:05:21 AM • Dell 5130cdn... • Answered on Aug 16, 2014
0answers
0answers
5130 CDn blCK TONER IS NEW BUT STILL LOOKS FADED
It could be in draft mode.
6/19/2014 5:55:08 PM • Dell 5130cdn... • Answered on Jun 19, 2014
Error codes
Hi, Plz vist this link and read care fully i hope solved your problem. http://www.dell.com/support/troubleshooting/ag/en/agdhs1/KCS/KcsArticles/ArticleView?c=ag&l=en&s=dhs&docid=622134 If not understand and solved your problem contact good TechSupportPrinter Technician.
1/20/2014 10:43:34 PM • Dell 5130cdn... • Answered on Jan 20, 2014
0answers
0answers
Dell 5130cdn Color Laser Printer Logo
55 questions posted
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Office Equipment & Supplies
Most Popular Question
reset fuser message dell 5130
  • Office Equipment & Supplies
