20 Most Recent
Teac (DW-224E) DVD Drive Questions & Answers
Driver for TEAC DW 224e-a
Here's the newest driver for your burner. Go to Control Panel, thenDevice Manager, then click on the + symbol next to disk drives, anddouble click on the TEAC device. Click the Driver tab and press UpdateDriver, then choose the 'Let me find the driver' option, and navigateto the folder where you unzipped the file to. Double click and Install.Reboot.
http://www.softwaredriverdownload.com/download/driver/DW224E.ZIPFor burning, I would recommend Nero, Alcohol 120% or ImgBurn.
Good luck and Season's Greetings!
Chris (ziraffa)
TEAC CD/DVD problems
Hmm, sounds different to the usual problems I've come across but try this:
Paste the following into a new text document and "Save As..." type "All Files (*.*)" and call it "DVD Fix.bat"
@ECHO OFF
REG DELETE "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}" /v "UpperFilters /f > NUL
ECHO Press any key to restart the computer.
PAUSE > NUL
Shutdown.exe -r -t 0 -f -c "UpperFilters reg key removed to fix CD/DVD-ROM" -d p:2:3
Run the file and restart your computer when prompted.
If you're trying to write to a blank disc, make sure in the drive's properties that you have recording/burning enabled. If you do, try re-installing your CD/DVD burning suite. If you didn't have one, try a system restore.
If this doesn't work or you've disable system restore, you can go into hardware manager and roll-back the driver. If you don't have a roll-back available. uninstall the driver and restart your computer. A default Windows driver should then install.
Check the drive is physically performing - does it load/eject the disc? Does it spin-up? Are you able to read any discs?
I you have any further problems, it would help if we had the model name of your laptop.
Does not recognize cd/dvd, light blinks continually
It could be a problem with the lens, you should try cleaning the lens, it's already gone bad there is no harm in trying
if that doesn't work you can either repalce the lens or purchase a new DVD/CD drive
Teac dvd no hardware found
Click start control
panel administrive tools,computer management,device manager scroll down cd-dvd
rom drives you might see a yellow question mark ? right click you will
have options to update driver,roll back driver,or select properties general
troubleshoot, select driver click to reinstall drivers click update
driver or uninstall then reinstall if this does not fix the problem it might be
a registry problem if you cant see your disk drive in windows explorer
Close all open
programs
Click on
Start, Run, and type regedit and press
Enter
Click on the plus signs (+)
next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder
is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the
following names in the right hand column.
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
If any of the above keys shown in step
4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and
check to see if your CD or DVD drives have returned. You may also want to open
Device Manager and verify that the yellow exclamation and error code on the CD
or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug
them back this should activate the found new hardware wizard or
you might have to uninstall
then restart your computer then reinstall your DVD/CD then reinstall the driver
for this device
if your computer came with
a motherboard disk the drivers could be on it
click start control panel
administrive tools computer management device manager scroll down cd dvdrom
drives if you see a yellow question or exclamation mark?! or a red x
right click you will need to update the driver
or
select properties general troubleshoot, select driver
click to reinstall drivers click update driver
hope this helps
Problem is that my DVD
Download VLC (google it) for free, see if that plays the dvd. Most likely your player has an issue, VLC plays ANYTHING (pretty much!) without issue.
If that doesnt work then you'll have a problem with the actual drive.
When checking device manager is says the register
Backup all your important files.and emails
Try a Restore Point. Restore back past when the reg started error messages.
If unsucessful, sorry, means a complete reinstall/setup installation, but al least you will have saved your important docs, remebering to save to removable HD.
Need to replace the dvd
Hi a6291,
Your need to post back the model number of your presario, there must be 2000 different presario's out there. Typically, you need to take off the back panel, and then just two screws, but I won't know where the two screws are located until I know the model.
Thanks
Mark
Need to replace the dvd drive in my compaq
Have you disconnected both the POWER and the DATA cables between the motherboard and the DVD drive?
Is there any "slider" that "locks/unlocks" the drive into its "home" position?
Disc won't eject
Hi, to open thje the disc tray , look for a tooth pick , insert small hole in front panel push and back until disc tray out. , motor belt need to replace.
Teac dw-224e-a dvd rom will not read dvd +r -rw data
Reboot.
Chris (ziraffa)
Can't burn data
if it is burning audio and video format it mean the burning is all right, u must choose some other application for burn data cd, like nero burning rom or alcohol etc.
