20 Most Recent
Sharp Aquos LC65E77UM 65 in. LCD HDTV Questions & Answers
When turned on, why does it just display SHARP logo?
The logo displays when you turn the tv on. You need to select a signal from one of the inputs. Pressing the input button repeatedly will cycle through the inputs. As long as one or more of them is on and broadcasting you will find a picture.
Disable speakers aquos
In the audio setup screen , direct the sound to external. If you're using an optical cable then direct the sound to optical
Sharp aquos 60le8 willl not power up. power led is
power supply board is dead, do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this workout in solving the problem...
How do i turn the captions off on my sharp aquos
It depends on your connections. If you have a an antenna, standard cable from the wall, or a cable box connected with a coax cable u will have to turn it off using the CC button located under the panel on the bottom of you aquos remote. If your cable/satellite box is connected any other way besides coax, u will have to turn off the closed caption using the remote for that device...hope this helps.
Sharp TV LC60LE745U the screen remained black and an arrow on the bottom of the TV stay blinking
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
