20 Most Recent
Sony Ericsson W995 Cell Phone Questions & Answers
My sony ericsson w995 wont turn on
1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears•Release the power button but *continue holding the home button*, for another 30 seconds.StepThanks
I cant delete message recipients in my w995 phone
Try this , turn off the phone , take out the battery for about 5 minutes , reinsert the battery and let the phone boot up . This is usually a glitch and can sometimes be cleared by this method. Failing that , hook the phone up to your computer and go into the pc companion software that comes with the phone as it should be inbuilt , then delete from there.
Free unlock code
hi you can use codes to unlock your mobile .you can
get the codes from here
theunlockarena here they ask the
following details before rendering the codes they are
1.mobile model
2.country from where you brought the mobile
3.provider to which the mobile is locked
4.imei number of the mobile
finally they will send you the unlock codes once
you entered the codes in your mobile as for the instructions provided by them then your mobile get
unlocked and it will accept other network sim.
Sony ericsson ck131not sccept sim card
What message are you getting on the screen when you turn the phone on? Is it recognising there is a sim card there but not letting you use it? The most common reason for this is often a 'Locked' handset. Most networks set the phones the sell to only work for their sim cards. Most specialist phone retailers can usually Unlock the handset for a small fee.
If it isn't recognising that there is a card there it will either be a faulty sim card or a faulty phone.
My sony ericsson t700 internet settings does't install why
This phone was first released in 2008 and Sony's support for mobile phones by an agent is discontinued. In short, calling Sony for support won't help. The T700's technology was GMS/HSPA. T-Mobile and AT & T are carriers which access such. Whether either would assist you with setting up network connections is unknown to me. It sounds like your query involves the basic setup. I would review that in relation to the feature you are attempting to access and then query your carrier. But that route may offer no joy. The user manual has a troubleshooting section Here is the user manual for the T700 but there is a real question of your access to software updates for a 2008 release phone. I have no idea of the veracity of the service that claims to offer repairs or unlocking for this phone. This looks like an exercise in frustration. Sorry.
https://www.manualslib.com/manual/322716/Sony-Ericsson-T700.html?page=65#manual
Block stolen phone using imei
Unless you had an app like LookOut or Prey (highly recommend both) it is highly unlikely. Try talking to your service provider and see if they can track the GPS, otherwise you are SOL.
Unlocking code for sony ericsson S001 for free
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
