20 Most Recent Mtd Garden Tiller (Mtd) Questions & Answers
I inherited an MTD front
What to remember when working on these gas engines you have to have fuel spark and air usually on these small engines there is a screen in the bottom of the gas tank that gets clogged up check out the spark plug and take the air filter off and wash it in warm water with dawn dish detergent let squeeze all the water out of the filter and let it dry out a day or so hope this helps Merry Christmas
12/9/2017 6:05:19 PM • Mtd Garden... • Answered on Dec 09, 2017
2answers
I have an older 5 hp. Mtd tiller Do I have to use
Look on top of the machine.If there is an oil fill then no you do not use mixed fuel if yes it needs engine oil,30 wt.If there is no engine oil fill then you use mixed oil and gas,at a 50:1 ratio.
1/7/2015 3:03:42 PM • Mtd Garden... • Answered on Jan 07, 2015
0answers
I have a 21a-430-131 mtd when tine are in reverse it will jump out of gear
check the linkage for play and make sure its adjusted to go all the way into gear they will jump out of gear if its not going all the way in
8/14/2012 12:34:34 AM • Mtd Garden... • Answered on Aug 14, 2012
No spark older motor no points or cond. not enough spark to jump across plug gap changed coil magnet on flywheel seems fairly strong checked with meter shows some voltage but enough to see it
the coils do go bad but first check the gap between the coil and flywheel use a piece of a brown paper bag to set it
4/24/2012 10:10:13 PM • Mtd Garden... • Answered on Apr 24, 2012
0answers
Gas floods out of the exhaust manifold
Stuck float valve, letting too much fuel into the carb. Try taking the bowl off of the carb and checking to make sure that the float needle moves freely up and down. If there is evidence of gumming inside the bowl you will want to get some spray carb cleaner and clean everything in there thoroughly.
3/23/2012 11:54:59 PM • Mtd Garden... • Answered on Mar 23, 2012
0answers
Huskee model# 21AA45M5031 dual directin 18
3/3/2012 10:24:02 PM • Mtd Garden... • Answered on Mar 03, 2012
Mtd Garden Tiller (Mtd) Logo
49 questions posted
Top Mtd Garden Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
john h
Are you a Mtd Garden Expert? Answer questions, earn points and help others
View Most Popular
Mtd Garden
  • Mtd Garden
Most Popular Question
gas floods out exhaust manifold
  • Garden
