20 Most Recent Nokia IP 350 Firewall Questions & Answers
Launch Internet Explorer. Find whether the website you are trying to access is on the restricted websites list.
Remove the restriction by clicking "Remove" and then click "Close" and "OK."
Open the "Tools" menu and then select "Internet Options." Next select the "Security tab" and then "Sites.
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favourites Tools and Help
Select the site that needs to be unblocked.
You may choose multiple websites at a time.
Refresh the page by hitting the refresh icon shown in the Internet Explorer or simply Press F5 in your keyboard. You should now be able to access restricted websites.
Blocking Websites on Windows XP
Access the "Tools" menu and then go to "Internet Options." Click on the "Security tab," and then click "Sites." Next, click "Add."
Type in the URL of the website you wish to block. You may type in more than one web address at a time.
Click "Close" and then "OK" once you have typed in the websites you wish to block. Refresh the page by hitting the refresh icon shown in the Internet Explorer or simply Press F5 in your keyboard.
Hope this helps
Nokia IP 350... | Answered on Sep 28, 2017
You cannot connect your acer aspire one via HDMI as its not having HDMI port. But you can connect via VGA cable and most of the TV supporting HDMI will also definitely support VGA input.
Nokia IP 350... | Answered on Nov 20, 2016
proxyannouncer.com. this will help u out
Nokia IP 350... | Answered on Jul 15, 2015
It is easy to avoid all restrictions by using vpn. ( http://sahrzad.net ) but it is probable better to work are work :) Catch Barracuda or How to Get past Barracuda Web Filter Sahrzad VPN Blog
Nokia IP 350... | Answered on Jun 04, 2015
If you are in Saudi Arabia the best way to open blocked sites is vpn service. Virtual private network is a secure and safe way to open any site and stay anonymous. How to access blocked sites in Saudi Arabia safe and easy Sahrzad VPN Blog
Hello :
Here is are some solutions :
- VPN
A VPN lets you access Facebook from a normal internet connection. It’s a little bit of software that you install on your computer and then run after you connect to the internet. It sends all of your internet information through a different computer (located in the US or UK for example)… Try www.witopia.net for more information!
- Proxy
A less elegant option, but just as useful, is to use a web based proxy. There are many of these available, one of the best is ’sneak me’ (www.sneakme.net). You input the web address that you want to access and then click on ‘OK’ and you can go straight to the site you need.
- Business firewall bandwidth
Some businesses buy bandwidth directly from Chinese telecommunications companies, so multinationals for example can have full access to the Internet without any interruption.
Good luck .
please don't forget to rate !
Nokia IP 350... | Answered on Mar 25, 2014
Or not to open? That is the question.
Nokia IP 350... | Answered on Nov 04, 2013
how do i unblock myspace?
Nokia IP 350... | Answered on Oct 08, 2013
check the net gear compatibility with the fire wall to see if that is the problem. you may have the incorrect OES for the net gear unit
Nokia IP 350... | Answered on Oct 07, 2013
You may be able to use a vpn service if they aren't blocking that also. I have used the free version of http://proxpn.com but not out of the us. Basically you tunnel your internet browsing to another country so it goes from where ever the vpn pops out to the website and there is no uae firewall inbetween.
Nokia IP 350... | Answered on Oct 29, 2012
click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in facebook.com) or your preferred browser
internet search facebook login
once logged in in the right hand corner on the facebook homepage you will see ACCOUNT from the drop down list will be Edit friends Account settings Privacy settings Help center and Log out you could use the help center type in you problem you might have to wait a for 2/3 days for a reply due to overloading on this site also
http://www.filebuzz.com/fileinfo/87599/Facebook_Login.html
Facebook Login software is freeware specially designed for Facebook browsing. This simple application has many features for you. Application is more speeder and secures Facebook browsing than your normal...
If your Facebook profile is still unavailable after many days, then send an email to
info@facebook.com,
appeals@facebook.com or
disabled@facebook.com and explain them the issue.
http://www.facebook.com/help/?page=121467344601554
Once you send them an email, your account will be available again soon.
hope this helps
Nokia IP 350... | Answered on Oct 23, 2012
A Proxy is like a DNS, a directory and a divert route to INTERNET. It can be used for bypass firewall restrictions or to divert trafic in to fake sites.
Nokia IP 350... | Answered on Oct 03, 2012
An Android Tablets or others?
Nokia IP 350... | Answered on Apr 20, 2012
Nokia IP 350 Firewall Logo
Popular Tags
85 questions posted
Popular Products
Top Nokia Computers & Internet Experts
Anthony Ward
Anthony Ward
k24674
Ekse
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Nokia Computers & Internet
Most Popular Question
connect acer
  • Computers & Internet
