20 Most Recent Microtek ScanMaker 5950 Flatbed Scanner Questions & Answers
0answers
0answers
Have not used the scanner
Sorry to say but the microtek support site indicates that this scanner is for windows machines only.
2/3/2011 8:36:03 PM • Microtek... • Answered on Feb 03, 2011
Microtek scanner freezes when scanning large documents.
Try scanning using Scanwizard instead of using directly in Photoshop. If it freezes again, it might be some problem with your system since there's no indication of hardware conflict. Additional info like Microtek scanner model name and current Windows version. Normally, Adobe wont have any problem regardless the scanner model, as long the appropriate driver installed.
12/26/2009 6:55:07 PM • Microtek... • Answered on Dec 26, 2009
Need instruction manuel
This is all I could find on it. http://w5.twgp.com/pdf/bro5950(1).pdf
11/12/2009 9:16:25 PM • Microtek... • Answered on Nov 12, 2009
User receives message 'inssufficient memory to
Hi!
Are you using the the driver which came along from the CD included in the package? If so, have you tried acquiring the latest drivers and softwares from the website?
This could help you fix the issue. Well from the error itself, it means that it does not have enough memory. Could be that the wizard also requires a large one. What is the current memory capacity of the computer you are using?
Try doing the steps above, if this still does not fix the issue, notify me.
Best of luck. ;)
8/17/2009 2:40:35 PM • Microtek... • Answered on Aug 17, 2009
0answers
How to fix / clear unwanted color bands during scan
Try place a couple of pieces of white paper behind what you are scanning. Worked for me
4/25/2009 4:15:23 AM • Microtek... • Answered on Apr 25, 2009
Microtek Scanner installation issue
If running XP SP2, then try clicking Start > right click My Computer > properties > Hardware tab > Device Manager button > expand Imaging devices > right click on your Microtek ScanMaker > uninstall > Re boot > and let XP pick up the device and let the found hardware wizard configure it.
I have seen plenty of hardware that when following the devices manufacturer's instructions for install, such problems as you're having occur and XP SP2 usually will cure it, though you may still need the device manufacturer's CD (for the driver) in your optical drive.
This link: http://support.microtek.com/downloads/bymodelname.phtml?viewtype=2&srch_in=ScanMaker+5950&frmsearch.x=10&frmsearch.y=11&frmsearch=Search&frm_rqst=2&axn=1 will allow you to select between the 5950 and 5950 Pro then on the next page you will be able to download the latest XP driver for your Scanmaker among drivers for other Operating Systems also.
I hope this helps, and Good luck.
8/19/2008 7:08:26 PM • Microtek... • Answered on Aug 19, 2008
Colorful lines down the scanned pages...
This could be due to excessive usage which the scanner can not tolerate and as a result the movement of the scanning mechanism losses precision. So avoid continous scanning.
8/10/2008 10:42:31 PM • Microtek... • Answered on Aug 10, 2008
was there ever a solution for this issue. all of a sudden, i am receiving it too after scanning for several years. please email me at [email protected]
6/16/2008 3:44:17 AM • Microtek... • Answered on Jun 16, 2008
Scanmaker 5950
I need Scanmaker 5950
6/11/2008 9:38:03 AM • Microtek... • Answered on Jun 11, 2008
Solid black image with flatbed or adf
This particular scanner may not run to NTFS instructions.
Check Windows Help in my computer- for program Compatability
and try to reset the software to run as Windows 98 - it may work.
12/8/2007 8:43:03 AM • Microtek... • Answered on Dec 08, 2007
0answers
It doesn't move.
Be the first to answer 2/13/2018 4:21:03 AM • Microtek... • Posted on Feb 13, 2018Be the first to answer
Where to find wia driver
Google driver for Scanmaker 3800
11/20/2017 4:13:18 PM • Microtek... • Answered on Nov 20, 2017
How do I open Scanmaker 5800
use Paint
11/20/2017 4:05:42 PM • Microtek... • Answered on Nov 20, 2017
Light flickering - now not even flickering
Check using a new USB cable. Unplug everything else plug into USB except for mouse and keyboard. If not work. Un-install driver and software. Download driver and latest software. Reinstall printer using driver only. Then use Paint to test it.
11/19/2017 11:06:55 PM • Microtek... • Answered on Nov 19, 2017
Microtek ScanMaker 5950 Flatbed Scanner Logo
Popular Tags
20 questions posted
Top Microtek Office Equipment & Supplies Experts
Alexander
Grand Canyon Tech
Grand Canyon Tech
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
ScanMaker Microtek
  • ScanMaker Microtek
Most Popular Question
not used scanner
  • Office Equipment & Supplies
