20 Most Recent Tomtom GO 300 GPS Receiver Questions & Answers
Have you had a chance to review the user guide/manual, etc... ?
They can be found at on the TomTom website:
https://us.support.tomtom.com/app/manual/st/5/kw/go%20300/page/1
Tomtom GO 300... | Answered on May 02, 2016
not a good idea, as it is part of the circuit/antenna and needs good contact to function fully
Tomtom GO 300... | Answered on Oct 06, 2014
Although the code is 2 blocks of characters on the activation card just enter it into the device as 1 continuous code and it will sort itself out
Tomtom GO 300... | Answered on Apr 14, 2014
dud battery usually causes line to appear on screen before shutdown
Tomtom GO 300... | Answered on Mar 25, 2014
The card is activated to the unit it was originally purchased for.
The card can not be used in another device . They are locked to the device code
Tomtom GO 300... | Answered on Jan 19, 2014
if you mean the PC for updating then the USB socket is faulty and needs replacing.
http://compu-sat.co.uk/repairs%20usb%20charging%20&%20data%20port.html
Tomtom GO 300... | Answered on Dec 11, 2013
First, register your new navigation device:
  1. Go to www.tomtom.com/getstarted.
  2. Select your country, then click on Get Started.
  3. Follow the online instructions to install the necessary TomTom HOME software on your computer and update your new navigation device with the latest maps.
Tomtom GO 300... | Answered on Oct 27, 2013
Have you tried going back to your "Change Preferences" menu, etc. ... to switch back to the Germany map ?
Or (if all your map is under a single map file), try "Navigate to" and select and enter an address in Germany ...
It appears that the battery will not hold a (good) charge anymore. If it is still under warranty, contact TomTom to address that problem. They may replace the unit for you.
It is not unusual for (rechargeable) batteries to loose it's capability to hold a good charge if it is plugged in (to a power source) all the time, even while it is not in use.
It's likely that your map (data) got corrupted. You can recover by restoring your back-up copy of the map (that you'd previously done via TomTom HOME on your computer).
If you don't have a back-up copy, try using your computer's disk check utility to fix the file system and recover data (from the storage media on your GPS device). Just connect the GPS to your computer, no need to use TomTom HOME, just use the Properties tab and use the Tools to run a disk check (assuming you're using Windows).
If that doesn't work, you may want to purchase & download and install the latest copy of the map from the TomTom website (via HOME).
Tomtom GO 300... | Answered on Oct 17, 2013
Tomtom GO 300 GPS Receiver Logo
295 questions posted
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
View Most Popular
GO Tomtom
  • GO Tomtom
Most Popular Question
enter activation code go 510
  • GPS
