Most dishwashers leave some water at the base at end of cycle.
The problem is there if a large quantity of water is left when the cycle is complete. The most common is blocked filters in the pump sump. If this is clean then the next problem could be outlet hose or the kitchen sink waste pipe. Make sure the kitchen side is clear. If all this is ok then the blockage could in the pump itself. It will look similar to this item.
Hoover Drain Pump
im not a dishwasher repair man but i know about mechanical and electrical equipment. sounds to me like a motor has burnt or burning out probably with one of the pumps. if its during wash then its the wash pump if during drain then the drain pump (im assuming these are two separate pumps)
Your heating element is not working, It could be one of 3 things.1. Broken solder joint in the electronics (common on this model)2. Broken thermal overload sensor3. Faulty Element (not very common)I'd pull the front off and have a look at the electronics and take it from there.
The process for removing the lower front panel on a Hoover HED6612 dishwasher may vary depending on the specific model and year of your dishwasher. However, the following steps may be useful as a general guide:
Unplug the dishwasher from the power source and turn off the water supply to the dishwasher.
Locate the clips or screws that hold the lower front panel in place. These are typically located at the bottom of the panel and may be hidden by a small cover.
Use a screwdriver or other appropriate tool to remove the clips or screws.
Gently pull the panel away from the dishwasher, making sure not to damage any wiring or connections.
Once the panel is removed, you will have access to the internal components of the dishwasher, such as the pump, motor, and water inlet valve.
To reattach the panel, simply align it with the dishwasher and secure it in place with the clips or screws.
It's important to consult the manual for the specific steps and precautions before performing any maintenance or repairs on your dishwasher.
You posted to the category 'Dishwashers', but this looks like it is an Australian Hoover carpet cleaner?
If both lights are on and blinking than they are indicating a jam with the brush roll of your SmartWash.
