20 Most Recent LG (DAD-8020B) DVD-RAM Burner Questions & Answers
try using nero vision if you are burning a dvd video..that should work for you......are you just copying a dvd ? bapplay let me know howit goes.
LG (DAD-8020B)... | Answered on Sep 20, 2019
You have corrupt IDE drivers. You may need to re-install your motherboard chipset drivers. If that still does not resolve the issue then you may have to re-install Windows from scratch.
Please rate my solution to show your appreciation!
For more tips visit my blog at http://thegeektweet.wordpress.com
LG (DAD-8020B)... | Answered on Jun 04, 2011
Hi al_zahid,
There is no driver required for this drive as it uses the inbuilt window's support for dvd or cd ram drives.
The drive could not be working because of a bad lens which you can get replaced, or you can use lens cleaner to try cleaning it first.
If the tray is not opening up then it's the problem with the gears in which case you need to replace the tray gears by opening up the CD/DVD rom drive.
Hope this helps ...:)
LG (DAD-8020B)... | Answered on May 09, 2011
rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select no 4 for australia
also
make sure that the dvd-rw is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
also
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
only do the registry check if you cant see the drive/s in windows explorer/my computer
or it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
LG (DAD-8020B)... | Answered on Feb 06, 2011
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
LG (DAD-8020B)... | Answered on Feb 03, 2011
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
hope this helps
LG (DAD-8020B)... | Answered on Dec 15, 2010
what kind of OS do you have?? or you might need to double the inside connection it could be loose..
LG (DAD-8020B)... | Answered on Jun 12, 2010
Maybe it is the disks you are using. Perhaps a bad batch. Perhaps there is something patially covering the laser and inserting a cleaning disk could remedy the problem too.
LG (DAD-8020B)... | Answered on Apr 18, 2010
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4)This folder is the DVD/CD-ROM Drive Class Description in the registry.Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the
Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives havereturned. You may also want to open Device Manager and verify that theyellow exclamation and error code on the CD or DVD drive is gone.
LG (DAD-8020B)... | Answered on Apr 01, 2010
Question is not clear.
Change the data cable and see the results. If you cant eject the tray issue is with power, change the power connector and see
LG (DAD-8020B)... | Answered on Jan 18, 2010
The media you add is a DVD correct? If so, your DVD drive driver seem to not be working right. I would take the drive out and boot the pc without it in. Then shut it down and re-install the drive. If this doesnt fix the issue, try re-installing the drivers for your DVD drive. You might want to open device manager and uninstall the drivers before re-installing them. I had this happen to me once and this is how I got it working properly again.
LG (DAD-8020B)... | Answered on Aug 14, 2009
Can you copy the file to your local drive and play it ? If you can then it's no problem with CD Player. Which player do you have ? The file could be corrupted.
LG (DAD-8020B)... | Answered on Jun 30, 2009
Nothing to worry about, it all depends on what type of disc is in the drive at the time.
LG (DAD-8020B)... | Answered on Jun 02, 2009
LG (DAD-8020B) DVD-RAM Burner Logo
Popular Tags
30 questions posted
Top LG Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • LG Computers & Internet
Most Popular Question
computer not recognizing
  • Computers & Internet
