20 Most Recent
Avermedia AVerDiGi SA6832E RACK 32-Channel Digital Video Recorder - Digital Video Recorder - MPEG-4, H.264 Formats - 500 GB Hard Drive Questions & Answers
DVR Cplete Hung & freez
sounds like a software problem. could be on Windows or on the NVR software. best bet is to re-install windows formatting the hdd completely. once done re-install the NVR software. if that does not solve your problem have a look at the graphics cards in the unit as well as the hdd. they could be faulty.
12/9/2013 11:01:07 AM •
Avermedia...
Answered
on Dec 09, 2013
Certain cameras are showing the same video.
First you need to isolate the problem. Step one - make sure the video from the cameras is correct - use a monitor and check each input separate. If the video is correct, use one camera and start from input one on the DVR and check all inputs - in other words plug your camera in input 1, check for video to make sure is correct and shows up in the right place, than go to input 2. This way you check your DVR cards. If the video shows up, but in the wrong place - check the settings on the DVR - you might be able to change the physical input in the viewer.Or you might have a bad DVR.......do a search for DVR Doctors in Google - in case you need repair.
2/20/2012 8:12:24 PM •
Avermedia...
Answered
on Feb 20, 2012
My doorbell has gone quiet
It may have this silent option in either choice for volume or melody. My doorbell has numbered buttons that need to be pressed together with the button to open the door, in order to access these functions.
Another thought is that a battery needs to be replaced.
How can I reset my floureon h 264?
Press the reset button: Using a small tool like a toothpick or paperclip, press and hold the reset button for a few seconds until the DVR resets. This will restore the DVR to its factory settings, including the default password
