20 Most Recent Korg D3200 Digital Studio Questions & Answers
If you have electronic expeerience, take it to a repair shop. You can cause more damage okiong around if you don't know what you're doing.
Past that, contact Korg customer service for the schematic and parts list. The part should be available from Korg directly of from Mouser
http://www.korg.com/us/support/contact
Korg Parts Parts Is Parts Guitar Parts Amplifier Parts Korg Keyboard Parts
Mouser Electronics Electronic Components Distributor
Korg Full Compass
Korg D3200... | Answered on Jul 16, 2016
you can obtain undelet software to do this but do not use the machine too much before attempting the procedure, too much use might lead to the areas where data was stored becoming written over. If the data was very important I would contact a data recovery specialist, one with a proven track record.
Good Luck
Korg D3200... | Answered on May 29, 2015
Here's a link to to the korg site to download the manual and there is a link on the page to reset: http://i.korg.com/SupportPage.aspx?productid=223
Korg D3200... | Answered on Jun 13, 2014
do you want to sell it? how much?
Korg D3200... | Answered on Jun 30, 2013
Probably the button mechnisms are worn. The heavily used buttons often have the plating worn off and become intermitent. Have the button mechanisms replaced. Make sure to use the long life version of the buttons.
Korg D3200... | Answered on Jul 06, 2011
Make sure ALL of the interconnected equipment is powered from the SAME receptacle to avoid ground loops due to the safety ground. DO NOT Use two wire power or use ground lifting plug adapters. Make sure you use balanced lines, either XLR or TRS cables. Do NOT use TS cables.
Korg D3200... | Answered on Jun 02, 2011
See if you can download the original "demo song" into the unit and see if the demo works. Should be able to find that on the Korg site under support.
Korg D3200... | Answered on Apr 20, 2011
It sounds like your ROM battery, which the ROM contains and stores the patches for the keyboard, has gone completely dead and your keyboard is dead in the water. However, if you can get a MIDI to USB converter and get the battery changed, then you can reload the patches back onto the keyboard.
I have worked on a Korg M1 Workstation and have had to replace the battery(CR2032) and then had to run a program called "MIDI-OX" which also gave me access to the patches needed in order to restore the keyboard to factory patch settings.
http://www.midiox.com/
Take a look at this AFTER you have gotten the battery replaced. I will tell you that replacing most batteries is a very intricate job as, the bottom of the keyboard has to be removed, as well as a lot of the internal boards. I had to draw a diagram and mark certain pieces so I would know where they went and in what order they have to be re-attached. My advice is take it to someone who works on electronics unless you want to DIY (not recommended) to get the battery replaced.
Hope this helps.
Korg Music | Answered on Nov 21, 2019
Korg D3200 Digital Studio Logo
15 questions posted
Top Korg Music Experts
Michial Gueffroy
Poul Brinchs Larsen
Joseph Wright
Are you a Korg Music Expert? Answer questions, earn points and help others
View Most Popular
Korg Music
  • Korg Music
Most Popular Question
repairing korg d 3200 digital recording
  • Music
