20 Most Recent
Randell 20072SC R-134a Refrigerator Questions & Answers
Where is the drip pan
HI welcome to fixya The major mgf. use a pan that the compessor will set in the heat from it will dry up the pan. You can add vinegar to tray to kill any smells. I hope this helps.
Why is my evaporator, refrigerator and freezer not
Your system uses R-134a refrigerant.
If the compressor is running but it's not cooling, you probably have a refrigerant leak or possibly a restriction in your evaporator.
Unfortunately, refrigerant leaks are not DIY friendly, so my advise would be to call a competent repairman.
A/C
Yes, that model has the 134. It should also have a sticker on the a/c telling what kind is in it.
I have a custom built
If you were told to replace the entire compressor unit (condensing unit), the person diagnosed the compressor is most likely bad. Depending on the age of the unit, it is hard to tell if this is a good decision. Overall condition plays a role in the decision process as well.
2/10/2018 3:02:43 AM •
Randell...
Answered
on Feb 10, 2018
Where is the defrost timer located in hisense upside down fridge freezer on model NO# HR6BMFF520S
The defrost timer in a Hisense upside-down fridge freezer, model number HR6BMFF520S, is typically located within the control panel or the refrigerator compartment. Here are the general steps to locate it:
- Check the Control Panel: Start by inspecting the control panel of the refrigerator. Look for any knobs, buttons, or switches that control the defrost cycle. The defrost timer may be integrated into this panel.
- Inside the Refrigerator Compartment: If you don't find the defrost timer in the control panel, check inside the refrigerator compartment. It might be located near the temperature control settings or the light fixture. You may need to remove any covers or panels to access it.
- Consult the User Manual: If you're having trouble locating the defrost timer, refer to the user manual that came with your fridge freezer. It often contains detailed diagrams and information about the location of various components, including the defrost timer.
- Contact Hisense Customer Support: If you're still unable to locate the defrost timer, consider reaching out to Hisense customer support for assistance. They can provide specific guidance based on your refrigerator model and help you locate the timer.
Once you've located the defrost timer, you can follow the manufacturer's instructions for troubleshooting or replacing it if necessary.
