20 Most Recent Samson Resolv 40A Monitor Speakers Questions & Answers
Your best bet is to take them to an authorized repair center. You may also want to talk to Samson directly. Here is their support link-
Support SamsonTech
Samson Resolv... | Answered on Jun 26, 2015
You can safely connect your powered monitor speaker to either the monitor output jacks or the tape output RCA jacks on your XP510. In addition, you may download the owner's manual here:
https://www.manualslib.com/download/515708/Samson-Expedition-Xp510.html
Samson Music | Answered on Oct 31, 2018
Which amplifier specifically?
Samson Music | Answered on May 04, 2014
Here is a troubleshooting hint:
Put an incandescent lamp in series with the hot side of the power cord. This acts as a resetable fuse while troubleshooting so you don't blow fuses.
Schematics are hard to come by, but power supplies are easy to trace the circuitry.
Check filter caps and the diodes and THEN look for hot (temp) IC's and transistors.
Samson Music | Answered on Mar 17, 2010
I understand your pain - was googling for similar, and came across this post, 5 years prior. My SGC Nanyo Bass Collection has just started to play silly beggars with the pots, and a bridge fault. Nowhere online seemed to have any details of the wiring, as the problem is, as you say, the fact that all of the tone and volume pots are based on a printed circuit board. If theres a nick or short on the board, its a pig to replace, and I really wouldn't like to have to wire any pots onto it. I'm currently looking at the options of ripping out the old electrics and wiring it from scratch myself. If you're still after answers, good luck!
PS - noted that none of the previous replies are relevant to this - mostly going on about the amps or a Fender guitar??!
Music | Answered Yesterday
Hi there and cheers for examining my bio. I'm just Daryl Ibbott and I'm just residing in Arvada, CO . My own pops and good friend completed study from An In-depth & Unbaised Eat Sleep Burn Review
Music | Answered on Nov 30, 2019
Amazon
https://www.amazon.com/MT-540-Keyboard-replacement-supply-adaptor/dp/B00GQVUMEG
NewEgg
https://www.newegg.com/p/14R-02A5-01UZ4
To verify, often the voltage is stamped on the back of the keyboard, near the power jack. Should say 9V
Music | Answered on Nov 28, 2019
Try here; http://www.synthmanuals.com/manuals/technics/u90/user_manual/
Can you please Edit or add a comment to your question, what make and model of organ is it? Have you tried it in a different AC outlet? Do any lights come on when you switch it on? Have you tried the headphone output as well as the speakers? Does it have a line output? What happens when you move the volume knob and or the swell pedal, do you hear any noise?
Music | Answered on Nov 06, 2019
Have you checked that it is not the amp that is the problem? This is a fairly common thing to have the amp heat up and the thermal protection shut it down partly. Since the bass drops, a loose connection or bad guitar cable can cause that. If the signal becomes capacitively coupled only the treble will come through and be very distorted. Try a new cable. For the guitar, open the electronics area and look for loose or broken wire.
Music | Answered on Oct 21, 2019
you found it on search on net
Music | Answered on Oct 16, 2019
Samson Resolv 40A Monitor Speakers Logo
Popular Tags
1 questions posted
Top Samson Music Experts
Michial Gueffroy
Bernie Scott
Level 1 Expert
Lawrence Oravetz
Are you a Samson Music Expert? Answer questions, earn points and help others
View Most Popular
Samson Music
  • Samson Music
Most Popular Question
samson resolv 40a no sound power light
  • Music
