20 Most Recent
NetGear WG111T 802.11g/b (E82321) Wireless Adapter Questions & Answers
I instal my wireless adapter
Right-click on the Wi-fi icon in the bottom right corner of your computer display and select "Troubleshoot problems". Wait while the Windows Network Troubleshooter tries to identify and fix the problem.
I need installer
You can download the WG111T driver from this WEB site.
http://driverscollection.com/?H=WG111T&By=NETGEAR
Installed USB pod into connection on side of
Hello, yes you have to run the softwaare, because it the system needs to know the hardware that is pluged into it. But you can restore the system so it can well. Please vote me.
Hey when i plug my wireless adapter into a usb
Try the adapter in another computer first.
If the adapter gives the same problem in another computer, it's gone defective and you need a new adapter.
Try that first, and post a reply here if the unit works in a different machine.
NO DRIVER ON DISC
GO to this
link and download the software and install and enjoy...
All the best..
Do rate me :)
Wireless adapter stoped recieving internet and
>If you have a Modem, aside from that router, the modem might no longer be on bridged mode, which is required to make the router function
>check it... if that's the case give your internet service provider a call and have them set your modem to bridged mode and connect the router, since nothing was changed on the router it should be able to detect internet signals rightaway ?
>comments suggestions ratings and violent reactions will greatly be appreciated
My wg111t connects for a few seconds then
please increase channel number on router,it will fix your
recomended channel number is 11 or 09 for netgear adapter
and also you can upgrade driver for adapter
regards
prakash
After i install my netgear wireless adapter, it
Please perform the below steps to configure the wireless connection:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
7. Highlight thee SSID from the list that you want to connect to.
8. Type the security Key here and click on the 'Connect' button.
9. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
I am having a problem getting an ip address
Check the wireless access points in the area. There may be another with a stronger signal that you are connecting to. Then make sure that you are not set to automatically connect.
Netgear wirless adapter/router
Ususally when you have two different brand products, they seem not to work too well. Also, those type of adapters generally get bed reception.
I cannot connect my netgearWG111T
Wireless Adapter Installation
A. Install the software.
Note: Firewall and anti-spyware need to be disabled. They sometimes treat software installation as a behavior of a spyware and therefore will prevent installation.
Windows XP:
1. Please power on your computer. Allow the operating system to boot up completely and log in as needed.
2. Insert the NETGEAR adapter Resource CD into your CD-ROM drive. The CD main page shown at the right will then load.
3. Click the Install Driver & Utility.
4. Please make sure that you follow the Install Shield Wizard steps. Click Finish when done and turn off your computer.
B. Install the adapter.
Windows XP:
1. Please make sure that you shut down the PC first and then remove the power cord.
2. Please insert the NETGEAR adapter into the available expansion slot.
Note: If you have PCI adapter, connect the antenna to the adapter, making sure the antenna is in the upright position.
3. Reconnect the power cord and reboot the computer.
4. When the Found New Hardware Wizard displays, please click on Next and then follow the prompt. If you are prompted with a Windows XP Logo testing message, just click on Continue Anyway.
5. After the installation completes, click Finish to close the wizard.
Configure the NETGEAR adapter.
1. Please Double click on the NETGEAR icon on the right lower end portion of your computer.
Note: If you do not see the icon, click on Start and go to Programs. Locate the NETGEAR Utility and click on the NETGEAR Smart Configuration Utility.
2. Click on the Networks tab.
3. Click on the Scan button.
4. Select the Network Name or SSID of your wireless network.
5. Click on the Connect button.
6. You will be directed to the Settings tab.
7. Type a name for the Profile.
8. The Network Name (SSID) will be the same with your wireless network.
9. Make sure that the Network Type is set to Access Point (Infrastructure).
10. Select the Security that you are using on your wireless router.
11. Click on Save Profile.
12. Click on the Apply button.
Enabling Wireless Zero Configuration Utility
1. Please click on Start, Run and type in services.msc and click on OK.
2. Scroll down and look for Wireless Zero Configuration. Right click on it and click on Start.
3. Right click on Wireless Zero Configuration again and click on Properties.
4. Under the General tab, set the Start up Type to Automatic and Service Status to Started. Then, click on Apply and OK.
Connecting to the Wireless Network
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
For Windows Vista:
1. Click Start then select Connect To.
2. Connect to a network window will show up.
3. Select your wireless network and click Connect.
4. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
We hope that the above steps provided would help resolve the problem. If the steps above did not work, we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Can your computer go online when it is hardwired to the router?
2. What wireless adapter are you using?
3. What is the operating system of your computer?
WG111T config problems
http://kbserver.netgear.com/release_notes/d102803.asp
Download version 1.3
I was running into the same issue when I formatted my computer. It worked fine before that. I downloaded the version 1.3 though and it installed easily. There are step by step instructions how to install it as well. Hope this helps!
WG111T
The solution I have is quite simple. I use Vista premium x64 so someone else can test it on Xp but it should work for both. In Vista the 1.3 version doesnt work so Facid's solution doesnt work for me.
[LIST=1]
[*]Get the 2.1 setup for Vista and install it.
[*]Go to your NETGEAR folder wherever you installed it to (Program Files x86 for me) and copy the DRIVERS folder to your desktop.
[*]Uninstall the smartwizard and remove everything in the NETGEAR folder.
[*]Plug in your WG111T.
[*]Go to Device Manager and find your WG111T in the list, Right Click and Update Driver.
[*]Browse to the DRIVERS folder on your desktop when it asks where to look for the driver and the WG111T will install. It should popup with a little message when it is completed but you will not be online yet.
[B]I dont know what you would do in Xp x64 system but I believe it has its own wireless manager like Vista and should be quite simalar.[/B]
[*]IN VISTA go to the Connect To button in your Start menu, It should be under Computer and Network, it should show your router along with a 5 bar network strength graphic.
[*]For me all I had to do was double click on the network and put in my WEP hex key and it conected.
[/LIST]
Gamertag: NeoNMD
Wg111t
Hi - Well, I do have one thing for you look for -
what type of network access are you trying to set up?
I'd just reinstall the software again (don't worry about the uninstall yet) and say okay if it asks if it can overwrite the files.
With the type of card you are mentioning, you are probably going to have to set it up to access as WEP (instead of WPA's). That was what was wrong when we installed one of these two weeks ago. I was trying to connect to the WPA-personal that I'd set up the router to and already had one computer set up for. I had to change the entire network setup (including router) to WEP to accommodate the new connection! (And WEP is slower than WPA's.)
I hope that is the only problem for you.
