20 Most Recent
NetGear MA101 802.11b Wireless Adapter Questions & Answers
No installation CD for MA101
You can downmload the needed software and much more at the Netgear factory support site, just google "NetGear software and drivers"
Wireless adaptor was working fine until xbox live
To connect your Xbox 360 gaming console to a NETGEAR router's wireless network:
- Turn off your Xbox 360 and disconnect anything from the I/O port on the back of the console.
- Insert your Xbox 360 wireless adapter to the I/O port as instructed by the wireless adapter manual.
- Connect the wireless adapter cable to your Xbox 360 I/O port.
- Flip up the network adapter's antenna.
- Turn on your Xbox 360.
- If you are using an unencrypted wireless network, your Xbox should connect to it automatically and you do not need to proceed to Step 6.
- If you are using an encrypted wireless network click the System tab, and then click Network Settings and continue with Step 6.
- On the Network Settings page, select Edit Settings.
- On the Edit Settings page, select your wireless settings on the Basic Settings tab.
- On the Select Wireless Network page, select your wireless network.
- On the WEP Network page, type your wireless network key, and then click Done.
- On the Apply Settings page, click Test Xbox Live.
- If this is the first time you have connected your Xbox 360 to Xbox Live, you will probably be prompted to apply an update. If there are no updates, the Xbox Live Connection page shows that you're connected to Xbox Live. Press the Y button on your controller to continue.
If testing the Xbox it says DNS failed, then update your NETGEAR router firmware:
- From your computer, open an Internet Browser and navigate to http://kb.netgear.com to download the firmware for your router.
- Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
- Click Router Upgrade on the top left pane under Maintenance, browse for the firmware downloaded and click Upload.
- Wait for the router to reboot.
Netgear MA101 802.11b wireless needs secure code for router
Is there any computer online using the router.
If not then you will need to connect the computer to the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Need the driver for this, where do I get the web site for it?
This product appears to be end of life. If you go to netgear's page and click on support > then Downloads> put a check mark on display end-of-life products. And you will see this device. You also click on this link to go directly there. http://kb.netgear.com/app/products/model/a_id/2487
Netgear 101Ma Not woking on my laotop
Go into your admin services setting from conrol pane, and go into services and then to wireless zero services and turn it off. Windows is probably conficting with the cards own software...
Network woes with MA101
Question
What is a "code 2" error
Question
What is a "code 2"
This error occurs when the BIOS did not assign an IRQ to the device. This is most likely to happen on a system that is not PCI compliantand/or is not capable of Bus Mastering. In such a situation a suggested ISA Ethernet Card would be the best sol
Error message "No domain server is available to authenticate user password"
There are any number of reasons this can happen. Please check for the following:
Verify ALL connections to the network are valid (cables, connectors, ports, etc.)
If there is no NT Domain server on the network:
1. Right-click Network Neighborhood, then select Properties from the list.
2. Double click Client for Microsoft Networks.
3. In the new window that appears, uncheck Logon to NT Domain. Click OK on all open windows, and restart the computer when prompted.
If there is an NT Domain server on the network check to make sure that:
1. An IP address has been specified.
2. The computer has been configured for DHCP.
If DHCP is configured and the error message continues to come up, ensure that the DHCP service is running correctly. Contact Microsoft, or your network administrator for assistance with this.
for more clarification log in to http://kbserver.netgear.com/
Got connected, but no recieved data
Firstly don't encrypt your connection until it is up and running.
Depending on your router, if you require it to allocate IP addresses automatically you have to make sure enable DHCP is ticked, otherwise see what the IP address of the router is e.g 192.168.2.1 and set your network TCP/IP properties to 192.168.2.2 or any last digit as long as it is not the same.
This is the router IP address and not your ISP address.
Lastly set up your encryption but there are two ways of sharing the connection, one is called a 'wep shared key'; the other 'wep open' so make sur your pc wireless network is sharing the same type of WEP.
Hope this helps
Please rate this solution.
How to connect PC to netgear WIFI extender
By connecting to your existing WiFi network and enhancing coverage, the NETGEAR range extender enhances your home WiFi network. The steps below will assist you in setting up your extender.We recommend using the Nighthawk app to set up your extension on our latest devices. See the following articles for more information:https://pnews.org/boost-your-speed-with-netgear-nighthawk-r7000/
11/18/2021 3:59:41 PM •
NetGear...
Answered
on Nov 18, 2021
Belkin f9k1106v1 range extender not connecting
QUICK TIP: When finding a location for your range extender, it is best to place it within the same room as the computer.
You can also use https://192.168.206.1 to access the range extender's web-based setup page.
Step 1:
Place the range extender in an area where the Wi-Fi signal of your router is strong, but near where you want to establish your extended network.
Step 2:
Plug in the power supply of the range extender and make sure that it is powered ON. Shortly, its light will begin to flash blue and orange.
Step 3:
Place your computer near the range extender. Also, make sure your computer is not wired to any other network devices.
Step 4:
Connect your computer to the range extender by opening the list of Wi-Fi networks and selecting Belkin.setup. Confirm that the list shows it's connected.
Step 5:
Open a web browser, enter https://belkin.range into the Address bar, and follow the on-screen instructions. Don't forget to type "http".
Once the setup for your range extender is complete, you may connect the computer to its Wi-Fi.
9/12/2021 1:30:03 PM •
NetGear...
Answered
on Sep 12, 2021
How can i connect Netgear AC1750 Wifi Mesh Extender manually ?
By Following these steps you can easily setup your Netgear wifi range AC1750 extender
- Turn On Your Extender by plugging it into the power outlet, Wait till the extender is turned on and the power led light to stop blinking Once the device is fully booted up,
- Now open your web browser, enter mywifiext.net in your web browser if you are Are going to setup your range extender using the window device.
- Click on the New Extender Setup , Now Create a new account in case you do not have an account Already.
- Accept the term and conditions, Click Continue
- Now you will be asked whether you want to Configure your Netgear extender as a wifi extender or as an access point
- Click as a Wifi Range extender
- Now choose the network you wish to extend and click on the Next button
- Enter the password of your current wifi and click next
- Be Patience and wait for few seconds.
You had successfully setup your AC1750 Netgear range extender, in case if you are facing an issue with login into your Netgear extender read our
extender login guide .
5/6/2021 2:30:13 PM •
NetGear...
Answered
on May 06, 2021
How can I check netgear extender firmware update version?
By following these simple steps you can
update the firmware on your netgear Wi-Fi extende.
- First of all, connect your extender to your router Connect to your extender's Wi-Fi network.
- Visit at NETGEAR Suppor website
- Enter your extender's Model Number or Product Name.
- Click Downloads.
- Select a firmware version and click Download.
- Unzip the file if needed.
- Enter mywifiext.ne. in your web browse.
- Enter the extender admin user name and password.
- Click Firmware Update.
- Click the Browse button, then locate and select the firmware file that ends in .img or .chk.
- Click the Upload button. The firmware update starts and the extender restarts. The firmware update process takes about two minutes.
If you still face any problem so you can watch this video :-
4/29/2021 7:59:20 AM •
NetGear...
Answered
on Apr 29, 2021
How do I manually update the firmware on my NETGEAR WiFi Extender?
update update the firmware on your netgear Wi-Fi extende.
- Click Downloads.
4/26/2021 3:31:43 PM •
NetGear...
Answered
on Apr 26, 2021
