20 Most Recent Philips 50PF7321D 50 in. Plasma HDTV Questions & Answers
2answers
Hi, I have a Philips 50PF7321D/37
hi! my friend, you problem is similar to one i had with my 50pfp5332/12 philips tv. the problem is the power supply board. yiou must change it. it receives the energy but is unable to convert it in a correct way. good luck with the fixing. (by the way, i really need the part 05DRDW2A, and can´t find it in portugal, could use a litle help with that...)
3/5/2018 2:26:06 AM • Philips... • Answered on Mar 05, 2018
I have a 50pf7321d 50"
Oh. It's Great. Never show it to anybody!!!!!
6/29/2017 8:11:54 AM • Philips... • Answered on Jun 29, 2017
My Philips 50PF7321D/37 TV picture turns blue after about 30 secs of being on and I cant seem to get it to stop. Also when I turn the TV on it has a black screen with sound for about 15 secs before it
Unplug both the set and a box or receiver if used with the set, remove from power for several minutes and replug all to see if a reboot will help or not.
12/10/2012 1:59:57 PM • Philips... • Answered on Dec 10, 2012
2answers
I have a 50" plasma Philips tv 50pfp5332d/37 it
Most Common problem is Bad Capacitors on the power supply board, they will be vented or swollen on Top. 1000uf 16v 2200uf 10v 3300uf 10v
8/30/2011 9:41:16 PM • Philips... • Answered on Aug 30, 2011
A yellow line going down
you likely have the "screen size" option set to allow the TV determine the best size (3:4 , 16:9, ...). Set it manually to 16:9 for HD channels or 3:4 for low-def channels.
The line should go away. This is a common problem on Samsung, Sony (Green line right side) and Phillips (yellow line left side).
5/5/2011 1:40:32 AM • Philips... • Answered on May 05, 2011
My power comes on, then the green LED light
I am definitely a girl explaining this because I don't know the correct parts of the tv. Here goes. We had the same problem last year, called philips they advised I do a software update on the tv because that fixes everything....wrong. The light still flashed and no picture. I called them back and they said I had to find a philips tv repair to take it into....got lucky because there was one close by. Come to find out it was some board inside that cost $400 to repair. I thought cool it's cheaper than a new tv! Worked great until about 2 weeks ago the tv turns on and the light is green and picture pops up a minute later. Oh boy more problems! As I sit here right now my tv no longer has a picture. The green light is on but nothing. It's funny because we had it repaired this time last year. I'm fed up and buying a new tv!
4/4/2011 5:14:15 PM • Philips... • Answered on Apr 04, 2011
Hello...I'm worried about my philips
Vertical problem in your TV.Either loose connection.Try to resolder the vertical section.
4/4/2011 11:33:40 AM • Philips... • Answered on Apr 04, 2011
My Phillips 50PF7321D Plasma t.v. has a flashing
Red light flashing 6 times
12/27/2010 8:59:51 PM • Philips... • Answered on Dec 27, 2010
50 inches plasma tv the power not working just
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$???????
2. Open your TV and find PSB. Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
I have a tip/tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and Good luck.
Kaufman605
12/12/2010 10:27:13 PM • Philips... • Answered on Dec 12, 2010
My philips has a blown
Try Radio Shack the fuse will cost u like about $1.These modern tv just don't blow fuse like that,the power supply board have some kind of malfunction parts some where,u must have a good knolege of electronic to troubleshoot to find out which part it is.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
11/23/2010 10:44:37 PM • Philips... • Answered on Nov 23, 2010
Philips Power supply flashes 5 times
one day not start his open. stan by red led and after switch on ,his green bligkig is not open.sound is ok.(the relay his not click)
9/4/2010 5:55:14 AM • Philips... • Answered on Sep 04, 2010
My tv won't turn on red light keeps blinking
I am suspecting some slow and swelled capacitors in the power supply board. If you are technical ,I can guide you fix yourself. A shop should be able to fix for less than $200,if they can repair this board
6/2/2010 8:22:09 PM • Philips... • Answered on Jun 02, 2010
The unit does not turn
The clicking sound you hear is the power supply board trying to power up the screen. Most likely a component on one of the PS boards.
There are a couple of options you can do.
1. Leave the TV unplugged for about an hour so the TV can discharge and hopefully reset itself.
2. If the is any manufacture warranty, best to use this option.
3. If you have some electronic experience, you can find a Service Manual for your TV over the internet for less than $20. This Service Manual will have the schematics, part number list, and test point for the circuit boards in the TV. The Boards the need to be looked at is the main power supply and the board the delivers power to the screen ( commonly called a backlight inverter board). The odds are it's a bad mini transformer or a capacitor. Replacement parts can be found by searching the internet by the part number list in the Service Manual. Whole replacement boards can be found at a good price at Shopjimmy.com or E-bay.
10/13/2009 3:48:17 AM • Philips... • Answered on Oct 13, 2009
Flasing red light where the on light is
I have a philips pf50 9630a/37 tv may come on or it may not unplug it and take a chance then comes the 6 steady red flashes followed by 3 rapid red flashes the screen had been completely replaced by philips a year and a half ago
4/20/2009 1:45:14 AM • Philips... • Answered on Apr 20, 2009
Philips LCD 42PFL3603D/F7 won't stay on until I've held the power button in a few times. The display comes on, then I hear a click and it shuts off. After a few cycles of this it stays on
Remove the cover on the back of the tv. Look for swollen or leaking capacitors. They kinda look like batteries. If they are bulging or leaking then that is your problem. You will have to de-solder the old ones off. Then solder the new capacitors onto the circuit board. Capacitors will cost about 20 dollars and installing them isn't that hard to do. It will fix your tv 99% of the time. So it is worth a try!
2/21/2024 9:36:48 AM • Philips... • Answered on Feb 21, 2024
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM • Philips... • Answered on Dec 13, 2023
Philips 50PF7321D 50 in. Plasma HDTV Logo
30 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
philips 50pf7321d 37
  • Televison & Video
