20 Most Recent
Dual Electronics XHDR6435 Questions & Answers
XHDR6435 radio was working fine
I just Spoke to tech support. This is what they said:
1. Key in the on position and the red power button lit, remove the face plate.
2. On the left bottom side press and hold the reset button, with a pen, for 10 seconds and let go. The red led on the right should flash.
3. Reinstall the face plate.
4. Push power. The unit should come back on.
Mine worked, and i was about to tear it out and return it. So try this first or even call tech support for Dual 1-866-382-5476.
Do I have ot pay?
You don't have to pay anything to ask a question at FixYa. Or are you asking about something else?
The cd will load and
Two reasons arre possible:
1. the faceplate contacts to the hoding connector cane be faulty, you can remove and check the position of the face plate and the pressure to the contact. clean and adjust if this works when pressed into.
2. The linking flexible cord would have snapped or cracked and so the display unit will not be powered or detected as the transfer data is not available to the main processor.
Remove the panel and check the continuity of the wire or replace.
My in dash head doesn't
Make sure the yellow wire is going to a constant power source. Try to find a wire that is still hot when the key is off.
