Speaker is receiving a signal but no sound is
Zombie post, I know... But, I have a solution for this. Remove the power amp unit from the rear of the sub cabinet. Remove the sheetmetal shield, noting the 4 allen screws on the side. Th daughterboard that the 4 screws thread into is a filter for the power amp's output, and is the last circuit that the powered signal goes through before hitting the speaker. If you inspect the solder joints, you will likely find that there are several which are bad. they will look cracked, potentially discolored in the crack. Resolder the joints, making sure to use good solder, and fill the joint. The most likely culprits are the 4 joints belonging to the 2 blade connectors which attach the daughter board to the larger board (which is the actual amplifier component). Again, sorry for digging this problem up from the grave, but when I searched for a solution earlier, this was one of the only posts that resembled my issues, and it never got a good solution.
