20 Most Recent
Kurzweil PC3K8 88 Note Performance Controller and V.A.S.T Workstation with 128 MB Sample Ram Keyboard, Hammer Action Keys, Black Questions & Answers
ERROR formatting card
If you have a card reader writer that accepts smart media cards then remove from keyboard and format via a computer.It may be fat16 and not fat32 ....a good utility is hp utility storage format tool which is a small file free to use off the internet.lastly because the card is so small you can get these for very little money off eBay.
PC3 freeze
Probably the battery is low insite it takes ling because it tries to juice the last life from the batterie will get worse until it stops replace it and go
Hi
As recently as a
Hopefully you didn't take it on a flight as sometimes they use bomb detecting equipment that subjects cargo to either high levels of radiation or high electro-magnetic fields. This can damage the equipment. It sounds like the processor is not running. There usually is a screen contrast control that can be turned enough that the screen appears blank, but usually you can get a sound out of the unit without reading the screen, Look in your user manual for a FACTORY reset or restore and pperform that procedure. If that doesn't work, then repair is in order. If unit has been vibraated during transportation, it is possible a cable has come off inside. Since you just bought this, EXERCISE you warranty immediately.
How do I restart when Kurzweil Mark 12 1999 piano hangs at waking up scanner message?
Hard reset procedure
1. Turn the Kurzweil off
2. Hold down the KEY START, KEY STOP, and LAYER VOLUME buttons for 5 seconds while powering the unit up, then release
3. Select RUN DIAGS
4. Press the UP arrow until the display reads RAM TEST
5. Press the START/STOP button to run the test
6. When the display reads SUCCESS, turn the unit off and back on. The unit is now reset.
If your Kurzweil still does not come up to the normal screen after this procedure, it will require service.
