20 Most Recent Roland Boss RC-20XL Loop Station Twin Pedal Questions & Answers
Reset RC 20XL to factory settings
I had to switch from 'inst + mic' to 'normal + flat amp simulate' in order to be able to delete phrase recordings.
3/9/2024 8:47:10 PM • Roland Boss... • Answered on Mar 09, 2024
Factory reset
Right, to you too...
12/14/2017 1:05:02 AM • Roland Boss... • Answered on Dec 14, 2017
When i press the record button for overdub, the light doesn't turn on. how can i fix the light?
It's doubtful that the LED itself is burnt out, so it's most likely a problem in the circuit. I doubt it will be user-servicable, so take it into the repair shop.
4/24/2016 5:46:45 PM • Roland Boss... • Answered on Apr 24, 2016
When i plug the cable in my boss rc-20 it turns on and instantly it turns off, how can i fix that?
I would suggest cleaning the input jack, and if that doesn't fix it, replacing the jack.
4/22/2016 10:21:57 PM • Roland Boss... • Answered on Apr 22, 2016
How to repair fried pedal ?
you throw it away and buy a new one. seriously. they're not worth getting into. with layered boards. if you have the expertise to identify the problem. you wouldn't be asking. - not an insult. they are just very problematic. one repair will lead to another. just keeps going.
8/17/2014 8:12:54 AM • Roland Boss... • Answered on Aug 17, 2014
I have a RC-20 xl
It is strange that it comes on when you plug into the OUTPUT... It should come on when you plug into the INPUT... could you have the jacks/plugs backwards? If cables are backwards, the bypass function will still pass your guitar backwards through the controls. You would NOT be the first person to mistake the labelling of input and output. There may be another problem of course, but do check the in's and out's. The fading out of the LED's is NORMAL when power is removed due to storage of the power by capacitors internally that bleed off.
9/16/2011 4:12:50 PM • Roland Boss... • Answered on Sep 16, 2011
0answers
2answers
When I power my Roland D20 up, all I get is bars
Hello. Hello. Generally the upper LCD display of bars is an indication that the internal battery is on it's way out and needs to be replaced.
In case you do not have the owner manuals, they can be downloaded from this address - enjoy: http://soundprogramming.net/manuals/Roland_D-20_Manual.pdf
3/28/2024 1:20:25 PM • Roland Music • Answered on Mar 28, 2024
I have a ROLAND BK5 keyboard instrument that has no sound out of speakers or headphones but it has new ribbon cables all components are working just fine except the sound
I wonder why the ribbon cables have been replaced as they do not fail. Check the keys actuate the contacts properly.
11/1/2023 7:57:00 AM • Roland Music • Answered on Nov 01, 2023
2answers
Damper pedal piano doesn't keep the tone properly
I can't! In my opinion, no. Start drift boss customize your car by choosing different colors and patterns.
10/31/2023 1:49:23 PM • Roland Music • Answered on Oct 31, 2023
ROLAND G70 . I HAVE LOST THE VISUAL OF THE MIDI
4/17/2023 4:19:13 PM • Roland Music • Answered on Apr 17, 2023
2answers
My Roland FP4 piano has suddenly ceased to power on. Is this fixable?
most likely we dont have crystal balls --need to have diagnosed for problem
4/10/2023 12:49:18 PM • Roland Music • Answered on Apr 10, 2023
Hi. Can I use the second pedal on my Roland BK5 to scale up the key one semitone at a time?
Yes, you can use the second pedal on a Roland BK-5 keyboard to transpose the key of the music that you are playing up or down by a semitone at a time. To do this, you will need to press and hold the second pedal while playing the keyboard. You can also use the transpose function in the settings menu of the BK-5 to adjust the key of the music that you are playing by a specific number of semitones.
1/5/2023 4:04:49 PM • Roland Music • Answered on Jan 05, 2023
Roland cube 80XL, making weird sound when it's on, nothing is plugged in, all controls down to 0
I am also using IOS and Android. So how can I improve some features? The black screen helps you relax when using the computer too much.
12/22/2022 6:43:06 AM • Roland Music • Answered on Dec 22, 2022
Roland Octapad SPD-30 dead.
Question edited for a bit more clarity. Video that might help https://www.google.com/search?q=Roland+octapad+spd30+dead Owners Manuals only. https://www.google.com/search?q=roland+octapad+spd30+service+manual ..
12/19/2022 1:50:50 AM • Roland Music • Answered on Dec 19, 2022
2answers
I need a circuit diagram for a Roland MA-15D speaker please?
It's a Chinese made Roland and no service information is available as when a fault is found the main board is replaced, eliminating the need for service information. I would check that it is a stereo out jack and not mono. If it is a stereo out, check that both input phonos work. If they do, replace the faulty socket or damaged pcboard.
11/17/2022 6:14:26 PM • Roland Music • Answered on Nov 17, 2022
My Roland KR 4500 powers up to a blank screen, no button led. No key sound.Power led is lit. Amp and speakers work fine with external sound input.
Sounds like a blown motherboard to me. It needs to go to the shop.
11/17/2022 9:46:44 AM • Roland Music • Answered on Nov 17, 2022
Where can I buy a motherboard for a Roland Fantom X7 OTHER than Roland?
I need fantom x6 motherboard!!! My whatsapp no +91_9760504606
9/22/2022 4:58:55 AM • Roland Music • Answered on Sep 22, 2022
Roland Boss RC-20XL Loop Station Twin Pedal Logo
8 questions posted
Top Roland Music Experts
NOEL
NOEL
Are you a Roland Music Expert? Answer questions, earn points and help others
View Most Popular
Roland Music
  • Roland Music
Most Popular Question
reset rc 20xl factory settings
  • Music
