20 Most Recent
Bushnell "Insta-Focus" Binoculars Questions & Answers
On my insta focus the
I think the DIOPTER SETTING of your binocular is misaligned, Visit this link to
download manual & carefully read the instruction for Diopter setting individual eye.
I hope this will solve your problem
Thanks...!!
10/23/2010 12:51:32 PM •
Bushnell...
Answered
on Oct 23, 2010
I have an old pair of bushnell binoculars. only
If you do an image search for Nikon Mikron and the one you have looks the same then you have a Bushnell copy from the 1950's called the Palm Pocket. These appeared in the 1950's. The 6x18 was available from 1951. The 7x18 and can be found in the Bushnell 1958 catalogue. By the 1965 catalogue they had gone from the product line up. If you look around the body of the binoculars you may find a code beginning with JB or JL followed by a number. This number will give the name of the Japanese manufacturer who made them for Bushnell. If you get the number go here for the codes
http://home.europa.com/~telscope/jbcode.txt
The Palm Pocket came in 7x18 and 6x18 designs. A larger model the Broadfield was available with 25mm objectives
8/1/2009 10:49:08 AM •
Bushnell...
Answered
on Aug 01, 2009
Bushnell insta-focus mechanism gets stuck.
they were famous for that, because the screwpin that holds the eyepice shaft is metal and the groove that it rides in is plastic, and eventually gets jammed....look where you put your fingers to adjust eyepieces. should be small metal plate in center of hinge(sometimes with bushnell logo) that will simply pry off by using small screw driver,and now you will be able to see if the screw is loose or damaged. good
[email protected]
1/16/2009 2:43:48 AM •
Bushnell...
Answered
on Jan 16, 2009
Insta-Focus focusing problem
first open and close the binoculars untill they fit you eye width,now adjust left eye with the flat section located on the center hinge,now turn right eyepiece till clear. note: once you have adjusted right eyepiece you only have to leave it in that position in order to focus from near and far.........good
[email protected]
11/25/2008 4:00:46 AM •
Bushnell...
Answered
on Nov 25, 2008
