20 Most Recent Zebra Z6M Plus Thermal Label Printer Questions & Answers
Error conditon ribbon out
if you are not using a ribbon you should configure your printer properties in direct thermal the same with your printer configuration in LCD Panel, if your printer properties is different with the LCD Panel error condition ribbon out will come out to your LCD Panel
3/1/2021 7:03:53 AM • Zebra Z6M Plus... • Answered on Mar 01, 2021
3answers
Printing error condition
First clean the sensor tag and sensor head open and tape. Then perform a calibration label pressing the PAUSE and FEED buttons and turn on the printer, release the keys until it starts to move the label. Wait until you are finished and ready to print.
3/1/2021 7:00:45 AM • Zebra Z6M Plus... • Answered on Mar 01, 2021
0answers
Printing blank label
You need to give more info. Are you using labelling software?
2/10/2016 1:07:20 AM • Zebra Z6M Plus... • Answered on Feb 10, 2016
Z6m won't stop feeding
I would venture a guess that the sensor that detects the labels isn't working well - it's supposed to see the difference between label and backing paper and stop at the correct position.
2/4/2015 8:50:43 PM • Zebra Z6M Plus... • Answered on Feb 04, 2015
Zebra Z4 Error message
ribbon in means, you choose direct thermal print method which is printing without a ribbon and yet you print with thermal transfer print method.
just check on lcd panel , change the print method to thermal transfer. and make sure the setting on your driver is thermal transfer too, or else it will keep reverting back to direct thermal
5/21/2014 8:12:08 PM • Zebra Z6M Plus... • Answered on May 21, 2014
I can't get my computer running windows 7 to
Z6M+ printer doesn't have USB port, how do you connect this printer to Win 7 PC? if you are using parallel / serial converter to USB then good luck. Ideally to get zebra external printserver and connect the printer through the network.
10/21/2013 9:49:25 AM • Zebra Z6M Plus... • Answered on Oct 21, 2013
2answers
Error print head open on Zebra 6m plus. Load
The sensor on this printer is a double sensor. The side close to the frame is the head open and the one on the outside is the ribbon present. It is adjustable. They both reflect off the chrome surface of the head assy. above them. First clean the chrome surface above the sensor and test before adjusting. There is one screw that you can loose and tilt the sensor to match the angle of the chrome plate above. Also the gap between the sensor and the chrome surface is .060in. or 1.5mm.
6/28/2013 6:18:41 PM • Zebra Z6M Plus... • Answered on Jun 28, 2013
0answers
Everything I try to print is being shrunk.
Welcome to FixYa.Check the "Printing Properties" of the software you are using to print. The "scale to fit media" or an option to shrink the printout must have been turned on or checked. Depending on the software you are using to print, it is usually found at FILE > PRINT > Printing Properties.Thank you for using FIxYa.
1/5/2012 8:04:32 PM • Zebra Z6M Plus... • Answered on Jan 05, 2012
Zebra Z6M Plus Thermal Label Printer Logo
52 questions posted
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Z Zebra
  • Z Zebra
Most Popular Question
z6m stop feeding
  • Office Equipment & Supplies
