Step 1:Firstly, restart the computer and check the print queue.
After the computer restarts, double-click the printer icon in the lower right corner (the notification area) of the computer. The print queue opens.
If theprint jobs remain in the print queue,continue to the next step
Step 2: Run theFixitavailable in the link below:
Troubleshoot-printer-problemshttp://windows.microsoft.com/en-US/windows-vista/Troubleshoot-printer-problemsStep 3: Make sure the printer is not paused or offline.
1. On the print queue menu bar, clickPrinter, and then look for thePause PrintingandUse Printer Offlineitems in the menu.
2. Make sure that there is no check mark next to either item. If a check mark displays next to either item, click to clear it.
Change-your-default-printerhttp://windows.microsoft.com/en-us/windows-vista/Change-your-default-printerStep 4:Run the fixit available in the link below to restart the Print Spooler service.
Fix printing problems by resetting the print spoolerhttp://support.microsoft.com/kb/2000007
You may try to add the printer locally and test
Add-or-remove-a-printerhttp://windows.microsoft.com/en-us/windows-vista/Add-or-remove-a-printer
turn the printer off then push the reset button in back then turn on and keep holding for 60 seconds and then release. this defaults the print server only, not the printer.
the issue sounds inpart to be related the set lable length, the printer thinks that the data will not fit on the label and gives the error. also note that the gap sensor is not in the center so the printer will not and can not autodetect the media correctly. you need to tweak the label setup. you could trick the printer by centering the labels over the gap sensor or if you do a autocalibating use the lable size it give you which would be much smaller then 17mm
