20 Most Recent
Zebra LP 2844 Thermal Printer Questions & Answers
Zebra LP 2844 printer will not print anything but the test page
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
Zebra LP 2844 doesn't stop feeding paper
I had the very same problem but I know it could be several different reasons. In my case it was a media calibration issue. To perform calibration switch the power OFF, then pres FEED button and hold it, Power ON still holding and after three red flashes release it. Calibration report will print out. At the end of that print you should get "PRESS FEED TO END". Do it and it should be ok. Let me know if that worked.
Zebra 2844 won't print anything.
Sounds like you may have taken out more than the fuse. In case there is still life the next thing to try is a printer reset
1) Turn printer off.
2) Hold down feed button whilst turning printer on.
3) Let go of the feed button as soon as it starts to flash and then wait.
4) Printer will measure out 4 labels then print out a Hex dump ending with a not to "Push Feed to Exit"
5) Push feed
Follow the above instructions, if you mess around tapping the feed button (not following the above) you can change the printer between line mode and page mode. To swap that back is another storey.
David
Printer is working but labels are blank
you need to have thermal direct labels to print to a thermal printer. heat turns the paper black. check your labels to see if you have thermal direct or tuern darkness up if it is thermal direct paper
Zebra Thermal 2844 prints text poorly
Lizardlick,
I found this information in the user manual:
Let the print head to cool for one minute, then use a new
cleaning pen to swab the print elements (the thin gray
line on the print head) from end to end. NOTE: You do
not have to turn off the printer to do this.
If print quality remains poor after cleaning, try the
Save-a-Print Head cleaning film to remove buildup
without damaging the print head. Call your authorized
reseller for more information.
