20 Most Recent Xerox Phaser 8400 Laser Printer Questions & Answers
You can download the driver directly from here:
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=8400&Xlang=en_US&Xcntry=USA&source=XOG
Just select which version of Windows 7, and the language.
Hope this helps. If so, please rate. Thanks.
Xerox Phaser... | Answered on Sep 09, 2014
You need to replace the counter chip that's in the maintenance roller assembly. You can find those at e-bay. Just make sure that there is enough oil at the roller and the blade is in good contition or else the ink wil stick on the drum and you'll have print quality problems
Xerox Phaser... | Answered on Aug 05, 2014
sounds to me like one of two things has happened.
More than likely the actuator tab on the cover snapped off,
Look for an opening around the edge of the cover , there is a cover interlock switch in there. Note its position and look at the cover to verify there is a tab on the cover to actuate the switch, Or you may have a loose connector on the interlock switch, or a bad switch, although I have never seen one of those switches go bad.
Xerox Phaser... | Answered on Jun 08, 2014
AC power supplied by power sources such as uninterruptible power supplies (UPSs) or DC-to-AC inverter systems may not supply correct voltage to properly power up the printer. Likewise, other devices sharing the same AC circuit can cause AC voltage sags that cause the printer to fail its AC heater PEST tests (Print Engine Self Test). The printer may produce the following heater errors:
37,005.41: PEST - Printhead Reservoir 1 disconnect. Reservoir 1 is not drawing
the expected power from the supply.
If the printer is plugged directly into a wall outlet and you still get this error, the Printhead is bad and should be replaced.
If you
Xerox Phaser... | Answered on Mar 16, 2014
This fault code indicates a problem with the process control system. The machine cannot successfully home the transfix mechanism.
Check for obstructions around the printhead. Look for ink shards in the gears of the tilt drive. Check the printhead wiring harness to make sure it is not blocking the printhead movement (left/right & front/back). Remove the waste ink tray and look for ink build-up.
Check the process drive gears for damage. Ensure the gears are correctly aligned and homed.
Check the nose cone alignment on the X-Axis motor. Is the nose cone aligned with the printhead shaft (left/right movement).
When you removed the square metal block from the printhead shaft on the Left side, did you reinstall it with the "dot" in the same orientation as the diagram above it shows with a check mark?
Check for obstructions in the Wiper Assembly path.
Look for ink build-up in the wiper belt channels.
Ensure the wiper system is properly aligned
Run the Wiper Drive test to see if it passes or fails...
Run the Wiper Alignment test to see if it passes or fails...
Run the Head Maintenance Clutch test.
Check to see if the Waste Tray is overfilled.
You can download the Print drivers from HERE. Make sure you select the PostScript Driver v5.48.30 or you can as well use the Global Print Driver, which you can download from the same link. Uninstall previous drivers and Install it as a Local Printer. Please be aware that if you are using a Server/Client structure the this instalation should be done on the Print Server.
After all that you should be able to print in colour. As a test print an Image file and make sure you confirm colour is enabled on the printing preferences of the driver. Alternative would be to print a test page from the driver. This will also show you the colour prints.
Xerox Phaser... | Answered on Feb 02, 2014
Problem:
The machine displays the Replace Maintenance Kit after the Maintenance Kit has been replaced.
Cause:
There may two causes for this issue.
  1. The machine does not recognize that the Maintenance Kit was removed. This would likely be caused by a defective Drum Maintenance Pivot Plate.
  2. The machine corrupts the CRUM on the new Maintenance Kit. This may be caused by a defective Drum Maintenance Pivot Plate or IO Board.
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix.
  1. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message does not change to "Maintenance Kit Missing," replace the Drum Maintenance Pivot Plate and install a new Maintenance Kit.
  2. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message changes to "Maintenance Kit Missing," replace the IO Board and then install a different NEW Maintenance Kit. If the problem persists, replace the Drum Maintenance Pivot Plate and install a different NEW Maintenance Kit.
ETI v1.3.20.0 610606.Replace Maintenance Kit Message after it Has Been Replaced 2007-11-18 21:37:39
Xerox Phaser... | Answered on Jul 03, 2013
1. Open Start menu.
2. Click on "Printers and Faxes"
3. Double-click the icon for your printer.
4. On the menu bar, click "Printer" to open the printer menu. Click on "Use Printer Offline" to remove the check mark. This will bring your printer back online.
If this did not help, check the printer itself & make sure it is not set to be offline.
Xerox Phaser... | Answered on Jun 11, 2013
power issue.
Check if the poweroutlet/cord is ok.
Otherwise engineer
Xerox Phaser... | Answered on May 31, 2013
First look at your printer identification.
You can see it in either the display or on the startup or configuration pages.
It must have a "D" in the name for you to be able to do automatic duplexing. i.e. 8400DN or 8400DX . Then you can scroll to printer setup
and select defaults, and then turn on the duplex, or double sided printing.
If yours does not have a "D" i.e. 8400, 8400N then you would need a new sim card to enable the duplex option.
Xerox Phaser... | Answered on Dec 04, 2012
Press and hold the Cancel button then press the Help button to change the Control Panel language.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Xerox Phaser... | Answered on Nov 08, 2012
When you go into the eliminate light stripes there is also a mode called Jet Substitution. You can sometimes bypass the bad jets.
If that does not work then the print head will most likely need to be replaced.
You can replace the printer for less than the cost of a print head normally..
Xerox Phaser... | Answered on Sep 19, 2012
Xerox Phaser 8400 Laser Printer Logo
345 questions posted
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Phaser Xerox
  • Phaser Xerox
Most Popular Question
printer says s off line print
  • Office Equipment & Supplies
